20 Most Recent
Apex Digital DT250A Digital TV Converter Box Questions & Answers
I need code number
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window " to get gathered related posts.
I need to know how to change modes without controller when I'm using a dvd
Without a remote controller, you may have limited options to change modes on your Apex digital TV. However, you may be able to change the mode by using the buttons on the TV itself.
Here are some general steps you can try:
- Turn on your TV and make sure your DVD player is connected to it.
- Look for the "Menu" button on the TV and press it.
- Navigate through the menu options using the arrow buttons on the TV until you find "Input" or "Source."
- Press the "Enter" button to select the input/source option.
- Use the arrow buttons to select the input/source that corresponds to your DVD player.
- Press the "Enter" button to confirm the selection.
- Press the "Menu" button to exit the menu.
Note that the specific steps may vary depending on the model of your Apex TV. You may also consult the user manual for your TV for more information on changing modes without a remote controller.
