20 Most Recent Bosch Exxcel WFX 3267 Front Load Washer Questions & Answers
If the machine has been moved recently, ensure that it is level and not leaning forward. Pull the dispenser completely out (pull as far as it will go, then press down on the blue section in the fab cond compartment to fully remove) make sure it is clean and free or fab cond and powder build up. Following the diagram, check that part 0412 is clear (this can be done when the drawer is out by putting some water in the dispenser manually and seeing if it flows quickly. A baby bottle brush can be used to clear it, if it is blocked.769ae95c-736a-45f2-a40f-6dd121e32863.png
Bosch Exxcel WFX... | Answered on May 04, 2013
If the motor is not spinning, you may have a burnt out motor or faulty Motor Control Board. Else, if the motor is spinning, fix the belt from the motor to the drum.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Bosch Exxcel WFX... | Answered on Oct 30, 2011
(no promises but it's worth trying this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Bosch Exxcel WFX... | Answered on Jun 16, 2011
Hi,There are quite a few solutions available here:http://www.fixya.com/tags/error_f04/page-5
Regards,Icom1
Bosch Exxcel WFX... | Answered on Apr 03, 2011
This sounds like a bad main control board. Try unplugging it for 10 minutes then replug an try again. If you get the same results replace the main controller.
Bosch Exxcel WFX... | Answered on Jun 16, 2010
hello is this letter followed by any number?
Bosch Washing... | Answered on May 07, 2020
check belt if one and motor turning if yes check cogs to drum
Bosch Washing... | Answered on Apr 16, 2020
The compression spring that runs the unit is broken. You should not try to run the unit at all with it in this condition because you can break the housing.
Bosch Washing... | Answered on Mar 21, 2020
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically. Check the clutch, motor coupler, brake assembly, transmission, and mode shifter or actuator. one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test.WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller.Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LIDSWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you may have selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
The item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Another test u can do to check the water inlet valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Bosch Washing... | Answered on Mar 19, 2020
check drive belt or drive motor if ok possible bad transmission or drive cogs broken
Bosch Washing... | Answered on Mar 08, 2020
Unknown what model it is - you can use the comment menu to give more information about your problem.
Possibly a child lock was set according to the Bosch WAE Range Washing Machine link below:
https://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes
Bosch Washing... | Answered on Feb 22, 2020
Bosch Exxcel WFX 3267 Front Load Washer Logo
18 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
leak detergent drawer
  • Washing Machines
