20 Most Recent
Parallax Power Supply Parallax 7100 Series 55 Amp REPLACEMENT Electronic Power Center Questions & Answers
It does not seem to be charging the batteries. 12
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
Lanzar sd82 input output plug layout
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi8krnznueCAxWxrokEHT0iBfoQFnoECA4QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fmanual%2F577337%2FLanzar-Sd82.html&usg=AOvVaw1NvtQPbnDX49X9-I6oRe-J&opi=89978449
