20 Most Recent
Water Pik WATERPIK SHOWER HEAD COMBO PACK HH & WALL Questions & Answers
Shower head leaks with running
the cartridge for your faucet needs to be replaced .what type of faucrt do you have?Let me know and i will try to assist further.
2/7/2009 3:59:53 AM •
Water Pik...
Answered
on Feb 07, 2009
How do i fix my water pik water want come out
The filters need cleaning or there is clog. Here is a tip. Get some denture cleaner put enough water in it. And put 4 to 6 tablets and let it soak 24 hours. If you have no power the fuse is blown. Check the outlet by using another device.circuits in bathrooms will have a reset at the outlet. Possibility. Blown breaker
How can i adjust the height of my shower head?
This usually means removing part of your wall,and extending your pipe ,but if you don't want to do that ,I believe home depot,sells a shower arm that adjustable ,to raise or lower the head
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
Yesterday
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
