20 Most Recent
Bosch HBC 86Q650B Electric Single Oven Questions & Answers
Hello we have bosch hbc
My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
Bosch HBC...
Answered
on Oct 27, 2011
Turntable not rotating
Ours has a turntable On/Off button. Check yours.
After that, you will need to take it out and either see if it has frozen up due to dried liquids, or if it's just gone bad.
If just bad, replace. If full of dried liquids, then clean up with WD40 until you can get it to turn.
Bosch HBC...
Answered
on Feb 01, 2009
Bosch built-in oven HBL8450UC/01 displaying error code 126
E-126 ERROR CODE ... received this morning due to some burned toast! After smoke cleared and the oven cooled down I continued to display the error. I decided to let it sit for a few hours and after reading that it would need to be reset by a technician ---- I cut all power to the oven and then back on. The oven reset itself allowing me to reset the time. All functions appear to be back as expected, so this could be an option to try if you receive this E-126 flashing error code saving a service call! Hope you are lucky!
Bosch Ovens
Answered
on Oct 22, 2020
Haw to stop ae118error for bosch oven HBL5450UC/02
E118/E218 Four possible causes.
Reversed high and low speed wires
Hall effect sensor not seated properly
Wire routing coming in contact with the rubber end cap on the cooling fan
Upper plenum coming in contact with the rubber end cap on the cooling fan
Bosch Ovens
Answered
on Sep 09, 2019
Bosch hbn565 oven error code E218
Bosch Ovens
Answered
on Sep 09, 2019
