20 Most Recent Bosch HBN 430560B / 430520B Single Oven Questions & Answers
Unplug the oven , then ohm out the heating eliment. My guess is that it is burned open.
Bosch HBN... | Answered on Jul 13, 2014
there is more to this than meets the eye if youre oven takes a long time on fan setting it may be thermostat but more likely to be fan not turning at all or quickly enough the stat capillary is above oven element and if fan not blowing air away from capillary oven stat will shut oven temp down too soon if using conventional heat eg no fan make sure there are no full size trays directly on bottom of oven this will block heat from bottom element effectively giving only half the heat output.
hope this helps
Bosch HBN... | Answered on Jul 07, 2011
good day,
hope this link below will solve your problem.
search for an author name peter reinhart.he specialize baking dough,crust and bread
Bosch HBN... | Answered on Aug 03, 2010
I detected a similar problem following the sudden appearance of Err1 in the display. (Oven 4-5 years old, and the grill element failed when it was 3-4 years old). This indicated a temperature sensor problem. My local dealer came with his Thermocouple and confirmed an "under temperature" reading on the standard and baking settings. I agree that the fan setting is probably OK. He replaced the sensor. I monitored the situation for a while and was not happy because an under temperature could be quite dangerous when cooking certain foods, and also causes problems when baking bread.
The location of the oven sensor is also a problem because it is at the top right by the grill which also serves as the top heat source.
I had corresponded with Bosch about this and their response was, frankly, less than satisfactory. In the end I decided to call out their engineer (cost £85-ish) who wired my oven up to his computer. In the end he said that the oven was working as it should be (despite it taking a very long time to actually reach the target temperature of 200C.
In my view of I want 200C, then I should get 200C, not an approximation.
Interestingly the secret info (not in the manual) is that the temperature bar readout does not indicate that it has reached the actual temperature, but may be 90% of the temperature (so if you want 200C you get 180C.
An unsatisfactory solution is to get an oven temperature of the meat probe type and put that in the oven, then you will get a more accurate reading of the temperature. You would need one that goes above 200C (my first one only goes to 200 but I have found another that goes to 250C). Mine is by CDN model DTP482, any good cook shop should stock this.
Andrew Finch
Bosch HBN... | Answered on May 05, 2010
More than likely the grill element has failed, and this could account for the oven not getting hot enough, as on some makes, the grill element is on at the same time as the oven element, so if the element has failed, then it will not be hot enough.
My advice would be fit a new grill element, and this hopefully will solve the problem of the oven not being hot enough.
Please rate my solution.
Thankyou.
Bosch HBN... | Answered on Jan 25, 2010
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single...
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
Bosch HBN... | Answered on May 27, 2008
REPAIR IS NOT POSSIBLE BUT REPLACEMENT IS BUY A NEW SWITCH
Bosch Ovens | Answered on Jul 03, 2020
WELL THEN TURN THE ONE THAT LOOKS LIKE A CLOCK AND SEE WHAT YOU ACCOMPLISH
Bosch Ovens | Answered on Jul 01, 2020
Certainly the hinge(s) are replaceable though while some are simple others are a major dismantling job - needing to take the assembly back to the point the hinges were originally fitted.
Parts list and diagram can be found on the link below.
https://www.bosch-home.com/us/supportdetail/product/HBL5032AUC/01#/Tabs=section-spareparts/
Bosch Ovens | Answered on May 18, 2020
Sounds Like child lock activated check owner manual or send us a model # glad to help more
Bosch Ovens | Answered on Feb 23, 2020
bad control board wont hold memory or battery if it has one
Bosch Ovens | Answered on Jan 18, 2020
Bosch HBN 430560B / 430520B Single Oven Logo
22 questions posted
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
just replaced oven but same
  • Ovens
