20 Most Recent Bosch HBL 755 Stainless Steel Electric Double Oven Questions & Answers
I found a users manual for Bosch wall ovens at Retrevo.com
http://www.retrevo.com/s/Bosch-HBL755AUC-Ovens-review-manual/id/925ci470/t/1-2/
Bosch HBL 755... | Answered on Feb 27, 2011
Same on ours... one seems like it is just softly lying against the gasket without a solid tight seal... doesn't bother the cooking much, it seems, but I hate little problems like this!
Will follow this thread to see if there is an adjustment for a DIY'er, without having to make a $120 service call...
We have here below the parts layout of your oven. The element you need to check if it is bad is the bake element which is located under cavity at the bottom of your oven.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110019&diagram_id=191359#d191359
Bosch HBL 755... | Answered on Nov 08, 2010
We have the cooling fans in stock for the upper and lower ovens. Enter your model # at www.appliancehelponline.com. Select your part diagrams will also come up. All parts come with installation instructions.
Bosch HBL 755... | Answered on Sep 18, 2010
Hi, well the only thing that can cause this is a shorted controller switch, or a faulty controller, sometimes it can be the thermostat, jammed on,or even a jammed relay, or relay driver.
However to have even a remote chance of a DIY repair one simply MUST obtain a service manual, this shows you how to troubleshoot and isolate a problem for repair. As many Symptoms may have widely differing Causes.
As a professional, I always advice that one should seek a professional, usually it ends up actually being fixed, and cheaper in the long run. Plus there is NO chance of electrocution.
below is your Bosch service link, you can get a manual from here or arrange for a service call.
http://www.bosch-home.com/us/bosch/customer-care.html
Bosch HBL 755... | Answered on Aug 30, 2010
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
Bosch HBL 755... | Answered on Mar 04, 2010
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
i am in the uk and i use barkeepers friend this usually shifts anything on steel i dont know if you use something different in the u/s.its a white powdery substance which you aply with a damp clth then wipe of as it dries works superbly.
there is a microswitch on the door inner it sounds like its come loose or broken away affecting its operating tolerances should be easy to replace.
Bosch HBL 755 Stainless Steel Electric Double Oven Logo
Popular Tags
37 questions posted
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
need download manual product
  • Ovens
