20 Most Recent Bosch HBL 745 Stainless Steel Electric Single Oven Questions & Answers
2answers
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
1/3/2016 6:16:18 PM • Bosch HBL 745... • Answered on Jan 03, 2016
Hbl 745 error rtds not cal, how do i get the food out
Did you ever get an answer?? Same issue here. Oven is 10 yrs old. Had a different issue the first year & won't be buying an expensive Bosch again.
12/24/2015 7:59:41 PM • Bosch HBL 745... • Answered on Dec 24, 2015
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer Use rotary knob to change this to CLOCK Touch TIME again and it will say ENTER TIME with the time flashing Use the rotary knob to change the time as required Touch START and the time is now changed Page 12 if you need it Bosch HBL745AUC Use and Care Manual
10/7/2014 8:50:08 AM • Bosch HBL 745... • Answered on Oct 07, 2014
2answers
Bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
3/31/2014 2:06:28 PM • Bosch HBL 745... • Answered on Mar 31, 2014
0answers
0answers
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
12/9/2013 10:49:59 PM • Bosch HBL 745... • Answered on Dec 09, 2013
2answers
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
10/31/2011 8:27:33 PM • Bosch HBL 745... • Answered on Oct 31, 2011
0answers
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
52 questions posted
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
bosch oven door not close tightly takes
  • Ovens
