20 Most Recent Kohler - Toilet - One-piece - Gabrielle - K14257-WS-47 Questions & Answers
call a plumber if you dont know what to do...
Kohler - Toilet... | Answered on Mar 04, 2019
Follow the instructions on p.12 of the following pdf:
http://www.geberit.com.au/web/appl/au/wcmsau.nsf/files/usr-pdf-Geberit_Outlet%20Valves.pdf/$file/Geberit_Outlet%20Valves.pdf
Basically, push down the 'full-flush' (big) side of the flush button and look at the side of the remaining (small) side of the button. There is a little slot that allows you to pull the small button out. You can then pull out the big side of the button which exposes a screw that allows you to pull the lid off.
Hope that helps.
Kohler - Toilet... | Answered on Feb 06, 2017
Fill vale needs to be replaced.
Kohler - Toilet... | Answered on Nov 30, 2014
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Kohler - Toilet... | Answered on Mar 23, 2012
It sounds like you need a 10" or 8" rough-in toilet bowl.
Kohler - Toilet... | Answered on Dec 04, 2010
adjust your water level float if you have one or turn your inlet for water up higher.
Kohler - Toilet... | Answered on Oct 19, 2010
The foam gasket stays on the inside of the tank, the only part that gets pushed through the hole is the hard plastic threaded part, then you add the rubber washer and the nut from underneath.
Kohler - Toilet... | Answered on Jun 27, 2010
I would take the flexible connector from the toilet and while directing the flow into a bucket open the angle stop, If the flow is normal you may have debris in the fill valve if the flow is wimpy there could be a defective angle stop or flex connector
try;
-plunger
-toilet snake
-you may need a plumber if these do not fix your problem.
Kohler - Toilet... | Answered on May 20, 2010
some carpet cleaning machines have little balls that stop the water at a certain hight in the machine. could have come out and thats what is plugging the toilet
Kohler - Toilet... | Answered on Mar 30, 2010
THEN DO NOT TURN IT VALVES OPEN SO FAR .THINK
Kohler Home | Answered on Mar 25, 2020
Contact Kohler service department for a free replacement
Bidets ' Bathroom ' KOHLER
www.us.kohler.com > browse > bathroom-bidets
Browse KOHLER bidets. Designed to complement the styles of KOHLER toilets and faucets. ... Puretide™ Quiet-Close™ Elongated manual bidet toilet seat.
Intelligent Toilets and Cleansing Seats ' Bathroom ' KOHLER
www.us.kohler.com > article > CNT121600001
KOHLER intelligent toilets sense your approach, open automatically and close and flush when you leave. Or a heated seat that nestles you in luxurious warmth?
Kohler Home | Answered on Feb 20, 2020
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Kohler Home | Answered on Jan 09, 2020
The only batteries are in the docking station. If the remote is attached to the docking station, take that off and set it aside. Next, carefully lift the docking station up and out from the mounting bracket. Look at the back of the docking station, push the two tabs outwards (away from each other) simultaneously to open the battery compartment cover. Replace the batteries (4 AAs) in the correct orientation. Reinstall the cover. Then replace the docking station on the mounting bracket and put the remote back on the dock if desired.
These directions are shown in the Homeowner's Guide (without the service parts) available on the product page: https://www.us.kohler.com/us/veil-intelligent-comfort-height-skirted-one-piece-elongated-dual-flush-toilet/productDetail/toilets/1120267.htm . Scroll down to the Installation section to find the link to the document. The current link to this guide is https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1226974_5.pdf .
I hope this helps.
Kohler Home | Answered on Jan 05, 2020
Request the parts list from Kohler.
Kohler Home | Answered on Dec 08, 2019
Kohler - Toilet - One-piece - Gabrielle - K14257-WS-47 Logo
Popular Tags
22 questions posted
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
remove lid kohler k 1833a cistern
  • Home
