20 Most Recent Braun Flex Integral 5416 Electric Shaver Questions & Answers
You can do it yourself if equipped. First, remove the foil and cutter. Then remove the swivel frame by removing the two tine screws, Next, remove the two scew covers on the bottom. These are found on either side of the plug recepticle and look like part of the trim. You can pry them off with a small flat jewelers screwdriver or similar. Remove the screws underneath. You can then gently pry the front of the case off from th bottom. Once case is removed, you can lift out the circuit board to access the battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find compatible battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If this is not something you can do yourself, shaveroutlet.com can do it for you. See info and ordering at the link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Braun Flex... | Answered on Feb 19, 2017
This model has been discontinued for several years. It is not likely that you will find another of the same model number.
Probably, the best you can hope for is to purchase a similar model. The most similar current model is the Braun 560. You can find it at shaveroutlet.com at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-560-series-5-shaving-system.html
Braun Flex... | Answered on Jan 09, 2013
You will find a compatible battery at shaveroutlet.com
To disassemble the shaver, start by removing the foil and cutter. Then remove the two tiny screws that hold on the swivel frame. Next, remove the two round screw covers on the bottom by prying them out. Remove screws found underneath. You can then gently pry the front and back covers apart from the bottom
Braun Flex... | Answered on Oct 17, 2010
So a very simple fix is to just clean the corrosion from the battery terminals inside the thermometer. You'll need a Torx T9 screwdriver (Maplin, eBay, Amazon, maybe pound shops).
Braun Health &... | Answered on Nov 28, 2020
fixya does not sell Braun parts. Try contacting Braun for a source.
Braun Health &... | Answered on Nov 24, 2020
Mr Google suggests:
  1. Braun Service Centre Directions
  2. Appliance Repair Service
  3. Address: 3, 1St Floor, Navjivan Society, Lamington Road, Mumbai, Maharashtra 400008, India Phone:+91 22 2305 1554
  4. Write a review
Braun Health &... | Answered on Jul 15, 2020
1. Insert a flat head screw driver (FHSD) on the opening shown on picture. 2. While pushing down, move the FHSD towards LOT (right at this angle) as you pull towards you. The goal is to have an opening at the arch. 3. Insert another FHSD (or hard plastic if you don't want to mar) at the arch if it doesn't open. The battery orientation signs are shown on the back of the battery cover. I hope this helps. Keep fixing!
Braun Health &... | Answered on Jun 19, 2020
Bring it back n tellum. I had a cordless hairclip n gut a new replace cause batt had ussue. Or ucud put some electrical tape on back to keepit from shortn or groundn
Braun Health &... | Answered on Apr 24, 2020
https://www.cnet.com/forums/discussions/samsung-smart-tv-turning-off-609897/
Braun Health &... | Answered on Mar 09, 2020
The basic method is:
  1. Dismantle handle.
  2. Desolder old battery and other connections from PCB.
  3. Remove charging coil, pressure warning light, pressure switch, PCB and battery.
  4. Replace battery.
  5. Reassemble PCB and other parts.
  6. Solder in connections for parts and new battery.
  7. Reassemble handle.
https://toothbrushbattery.com/guides/braun-oral-b-professional-care-1000-battery-replacement/
Braun Health &... | Answered on Mar 08, 2020
Hello, Unfortunately, E01 is an error meaning a problem with a component internally that is not repairable. Please contact the customer service team for further .
Braun Health &... | Answered on Jan 31, 2020
The drive unit is probably not seated correctly. It must be pushed down when reassembling in order to keep the motor contacts in the correct position until the case is secured
Braun Health &... | Answered on Jan 27, 2020
I took the file on a nail clipper and turned the impeller inside the unit. Remove the cleaning fluid from the unit. Turn the unit upside down, On the part that sticks into the large hole of the fluid reservoir you'll see the impeller. Just turn it it enough to dislodge any whiskers and try it again. Worked for me. Good luck
Braun Health &... | Answered on Oct 27, 2019
I struggled with this for a while too till I found a diagram. Place the wire spring and the flat detente spring (all the way to the bottom of the slot) in as shown in this diagram. When the trimmer plate goes all the way in, the spring will snap into its correct final position. Lee
Braun Health &... | Answered on Oct 24, 2019
shaveroutlet.com does repairs. email them at [email protected]
Braun Health &... | Answered on Sep 25, 2019
Braun Flex Integral 5416 Electric Shaver Logo
4 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
change batteries
  • Health & Beauty
