20 Most Recent Braun Flex Integral 6550 Electric Shaver Questions & Answers
shaveroutlet.com may have a PCB that could work in your 6550 model but from what I discovered it is not the same as the one you currently have. It will make the razor function but the LCD will not be available to show battery life. you will have a red and a green light only. If you can live with this than I would suggest contacting shaveroutlet.com. I have the same problem as I have a model 6550 and I have been looking for a replacement PCB ..Printed Circuit Board but have been unable to find one. Call Brian at shaveroutlet.com. I plan on contacting him next week ...Feb 7, 2013 with same problem
Braun Flex... | Answered on Feb 02, 2013
Don't.
Braun Flex... | Answered on Jun 14, 2011
You will find the correct battery type for Braun 5556u at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Braun Flex... | Answered on Mar 16, 2011
Sounds like the batteries need to be changed. You will find compatible batteries at shaveroutlet.com. See link below. You will need two
To open shaver, remove the two round screw covers on the bottom by prying them out. Remove screws underneath. Slide outer case off the bottom. You may need to reposition the lock to get it all the way off. Inside, you will need to unsnap and remove the black cover to access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Braun Flex... | Answered on Jan 05, 2011
This shaver model was very popular back in the 1990's. They aren't meant to last more than 10 years with regular use. They can be reconditioned, as replacement parts are available, but it's probably not worth the trouble. You've put your shaver to good use--it's time for a new one. You can offer up your shaver on eBay for parts as-is and actually make a little $$ (some people can make use of the parts, for those who repair these things). I'd recommend getting an 8000 series model. They are very well made and still quite a lot cheaper than the 9000 (Pulsonic) series.
Braun Flex... | Answered on Nov 07, 2010
the batteries need replaced as soon as possible. you will find the correct battery type at shaveroutlet.com. see link below
If you are not equipped to repair yourself, shaveroutlet.com can do it for you. See link below
Braun Flex... | Answered on Nov 04, 2010
You will find the correct battery type at shaveroutlet.com. See link below. You will need two batteries.
I suggest that you read the installation tip on the item page as well.
Also, does the green charging indicator light still illuminate when you plug the shaver in to charge? If it no longer lights, don't waste your time with the batteries because your have waited too long to change them and the circuit board is now damaged. Unfortunately, circuit boards for model 6550 are no longer available from Braun
Braun Flex... | Answered on Oct 09, 2010
I.fix problem
thanks
Braun Flex... | Answered on Oct 03, 2009
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Braun Flex... | Answered on Dec 29, 2008
I don't believe that the cell unit can be changed. It is rechargeable, so if it is not recharging it is probably kaput or your cord needs to be replaced. I looked through all the replacement parts for your shaver and there is no battery available. Here is an address where you can find a place to have it service if you want to or at least speak to someone regarding the shaver.
http://www.braun.com/na/contact/servicepartners/americas.country.html
thank you for using Fix Ya and Good luck to you.
Braun Flex... | Answered on Aug 22, 2008
So a very simple fix is to just clean the corrosion from the battery terminals inside the thermometer. You'll need a Torx T9 screwdriver (Maplin, eBay, Amazon, maybe pound shops).
Braun Health &... | Answered on Nov 28, 2020
fixya does not sell Braun parts. Try contacting Braun for a source.
Braun Health &... | Answered on Nov 24, 2020
Mr Google suggests:
  1. Braun Service Centre Directions
  2. Appliance Repair Service
  3. Address: 3, 1St Floor, Navjivan Society, Lamington Road, Mumbai, Maharashtra 400008, India Phone:+91 22 2305 1554
  4. Write a review
Braun Health &... | Answered on Jul 15, 2020
1. Insert a flat head screw driver (FHSD) on the opening shown on picture. 2. While pushing down, move the FHSD towards LOT (right at this angle) as you pull towards you. The goal is to have an opening at the arch. 3. Insert another FHSD (or hard plastic if you don't want to mar) at the arch if it doesn't open. The battery orientation signs are shown on the back of the battery cover. I hope this helps. Keep fixing!
Braun Health &... | Answered on Jun 19, 2020
Bring it back n tellum. I had a cordless hairclip n gut a new replace cause batt had ussue. Or ucud put some electrical tape on back to keepit from shortn or groundn
Braun Health &... | Answered on Apr 24, 2020
Braun Flex Integral 6550 Electric Shaver Logo
Popular Tags
19 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
model 6550 electrc shaver r nhow open
  • Health & Beauty
