20 Most Recent Braun Flex Integral 6520 Electric Shaver Questions & Answers
0answers
Diagram
Be the first to answer 1/6/2019 12:30:16 PM • Braun Flex... • Posted on Jan 06, 2019Be the first to answer
No power
The motor brushes may be bad. Take the screen off and turn the shaver on. Manually move the blade back and forth a bit and see if it starts to engage. If it begins to run when you do this, the brushes are worn. Braun does not make replacement motors for your shaver
7/19/2017 5:37:18 PM • Braun Flex... • Answered on Jul 19, 2017
0answers
2answers
Shaver stopped working today--no green
Here is an equivalent circuit diagram good enough to repair the circuit board - What I have found is that the batteries go bad, draw too much current and blow the fuse or in the case of mine, over current the transistors. Resistors are in ohms
' ' o
' Unknown ' '
' __ ' '
' -o' 'o- ' '
' -o' 'o- ' ' ST Micro
' -o' 'o- ' ' STD616A
' -o'__'o- ' '/
' -o' 'o-----' .-----------'
' -o' 'o- ' '>
' -o' 'o- ___ '/ NXP '
' -o'__'o--'___'------' BF820215 ' '
' 330 '> '---------''- --
' ___ ' 1.2V
'-------------'___'--------'
1.3K
750ma Pico Fuse
.-----. _
-'~ +' ----o_/ \o-----
DF08 Full Wave Bridge
4/26/2012 11:36:30 AM • Braun Flex... • Answered on Apr 26, 2012
0answers
Capacity of recharge went down to from 60 to 20
You will find compatible batteries for model 6520 at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To open shaver, remove the two round screw covers on the bottom by prying them out. Remove screws underneath. Slide outer case off the bottom. You may need to reposition the lock to get it all the way off. Inside, you will need to unsnap and remove the black cover to access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
12/31/2010 9:41:37 PM • Braun Flex... • Answered on Dec 31, 2010
How I change the battery and what is the cost of a
If the shaver still works but just will not hold a charge as long as it should, you can fix this by replacing the batteries. If the shaver is dead and will not run and the green charging light no longer illuminates when you plug it in, you will need to change the whole circuit board.
You will find the batteries and the circuit board with batteries at shaveroutlet.com. You can order which you require by viewing the links below
http://shaveroutlet.com/shaver-replacement-parts/braun-printed-circuit-board-with-batteries-p-106.html
To open the shaver, you will need to pry out the two round plastic screw covers on the bottom then remove the screws underneath. You can then remove the outer case by sliding it down and off of the shaver bode. Then remover the black plastic cover inside to access the circuit board and batteris.
If replacing the entire circuit board, you will simply lift it out and replace. If just replacing the batteries, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
11/7/2010 1:22:40 AM • Braun Flex... • Answered on Nov 07, 2010
Battery is fine - but green light showing recharge
Assuming that your cord is not damaged, the circuit board is bad. This most often happens when you continue to use the shaver well after the batteries have lost their ability to hold a charge well.
You will find a new circuit board for model 6520 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-106.html
4/1/2010 10:43:32 PM • Braun Flex... • Answered on Apr 01, 2010
Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
1/16/2010 5:34:05 AM • Braun Flex... • Answered on Jan 16, 2010
Braun 6520 - Putting together the switch
Is there a way to get pictures posted so we can see what you're dealing with?
11/18/2009 5:47:03 PM • Braun Flex... • Answered on Nov 18, 2009
The on/off mechanism on my dads braun 6520 is
Hello running girl, Have you looked to see if maybe the "lock-off" feature hasn't been engaged?
If you look at the razor, right above the on/off and sideburn trimmer selector, you should see a full bar that goes all the way across the shaver. Push this up toward the shaving head to unlock the razor and the shaver should work fine again.
This is a Braun design feature there to help prevent the shaver from accidently getting turned on when packed in your luggage, etc. and running down a fully charged shaver.
There is nothing like reaching for what you thought was a charged and ready to use shaver and discovering that it got switched on and ran the batteries down.
Other than having the lock off feature engaged, I can't think of anything that would cause the switch not to turn on, unless the shaver was dropped and damaged. If that's the case, you will want to have it looked at to make sure the printed circuit board hasn't been broken, etc.
Typically this isn't something that most folks can undertake a diagnois and repair, so I'd suggest you contact www.electricshaver.com or call them at 1-888-476-1785 to get an estimate for repairing it.
Hope you find this Very Helpful and best regards!
10/10/2009 1:52:27 AM • Braun Flex... • Answered on Oct 10, 2009
Rechargable battery run down
The problem is that your rechargeable batteries2.gif have become degraded to the point that they won't take and hold a charge. Because the batteries2.gif have become so badly degraded, that even with the power cord plugged in, you still can't use the razor with AC power either.
If you want to have the shaver repaired for you, you can contact www.electricshaver.com or give them a call at 1-888-476-1785 to get an estimate of the repair costs. Typically it takes about a week or less once they receive your shaver. They also stock most parts for many brands of shavers, including your Braun. I've used them for getting parts for several of my shavers and found them to be a very good company.
If you're handy and have a soldering iron you can disassemble the shaver and remove (unsolder) the bad batteries and solder in a new set. There are two small caps on the bottom of the razor that cover the screws that hold the body havlves together. Remove these with a small pick or small flat bladed screwdriver and remove the screws and carefully remove the body halves and that will let you get to the main board and the batteries.
Simply heat up your soldering iron and melt the end tabs off the batteries and remove them. Then solder in the new ones and make sure they are properly secured and have adequate solder on the tabs for a good connection. Put the covers back on and install the screws and and the caps and your all set for recharging the shaver. Let it charge for at least 8 hours and you should be all set!
So whether you decide to have the repair done for you, or do it yourself, I hope you find this Very Helpful and best regards
10/10/2009 1:39:43 AM • Braun Flex... • Answered on Oct 10, 2009
My braun Flex 6520 does not turn on. When the cord
The cost to repair this isn't going to be nearly as much as a new Braun shaver as nice as this one.
The problem is that your rechargeable batteries have become degraded to the point that they won't take and hold a charge. Because the batteries have become so degraded, that even with the power cord plugged into an outlet, you still can't use the razor solely on AC power either.
So whether you decide to have the repair done for you, or do it yourself, I hope you find this Very Helpful and best regards!
10/10/2009 1:31:05 AM • Braun Flex... • Answered on Oct 10, 2009
Braun Flex Integral 6520 Electric Shaver Logo
26 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
shaver stopped working today no green
  • Health & Beauty
