20 Most Recent Braun Interface 3105 Electric Shaver Questions & Answers
tip
Fix Model 3105 also Model 3612
The small plastic piece falls out when cleaning the head. It goes back in the left side of the removable piece. Hold it with the screen closest to your body and upside down. The small piece fits in the upper left with the square edge to the left in the small recess. It just sort of snaps in.
Mine is actually the 3612 cordless but they look identical from the photo. I have been trying to fix it for 6 months. When a new head had the same problem with the piece falling out, I decided it might be repairable. After I pushed the piece back in, it stayed. You can tell where it goes by looking at the taken apart shaver (With the head removed for cleaning). The shaver has a plastic pin sticking up on the left side. This pin is what lowers the trimmer when the shaver is assembled.
Hope it works for you.
Braun 9095cc shaver - can't deactivate the travel lock
I have the same travel lock problem with my series 5000. Also, I am having a similar problem with my other braun, the easy clean braun 5000, though it may still be intermittently used. I suspect that the travel lock problem is a braun common defect. After my braun razors die out, I'm finished with braun razors.
8/16/2021 7:05:03 PM • Braun Health &... • Answered on Aug 16, 2021
4answers
Braun Clean and Renew not working
I took the file on a nail clipper and turned the impeller inside the unit. Remove the cleaning fluid from the unit. Turn the unit upside down, On the part that sticks into the large hole of the fluid reservoir you'll see the impeller. Just turn it it enough to dislodge any whiskers and try it again. Worked for me. Good luck
8/15/2021 3:52:08 PM • Braun Health &... • Answered on Aug 15, 2021
Series 9 shaver. How can I insert the cleaning solution into the base station?
Cleaning under running water / Switch on the shaver (cordless) and rinse the shaver head under hot running water until all residues have been removed. You may use liquid soap without abrasive substances. Rinse off all foam and let the shaver run for a few more seconds.
5/2/2021 10:53:59 AM • Braun Health &... • Answered on May 02, 2021
How to clean body groomer onn on braun 5524
Remove the head and cutter. Clean both with soap, hot water and an old toothbrush. Use the damp brush to clean the body head area. https://www.directshaverparts.com/en/1469-braun-5524 ..
3/20/2021 4:57:16 PM • Braun Health &... • Answered on Mar 20, 2021
How to re-attach the metal spring on a vintage Braun Electric Razor with Trimmer Model #5564?
I struggled with this for a while too till I found a diagram. Place the wire spring and the flat detente spring (all the way to the bottom of the slot) in as shown in this diagram. When the trimmer plate goes all the way in, the spring will snap into its correct final position. Lee trimmerspringinstallposition-wcjy5cljug2w44525vz1ol4j-1-0.png
3/13/2021 2:49:39 PM • Braun Health &... • Answered on Mar 13, 2021
Where to send my braun 7526 razor to have the batteries replaced
Shaver Outlet can repair it. See link below https://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
3/10/2021 2:28:41 PM • Braun Health &... • Answered on Mar 10, 2021
Braun S3 razor comes on and off by itself
tom chichester says defective switch
1/16/2021 12:32:08 PM • Braun Health &... • Answered on Jan 16, 2021
2answers
My Braun thermoscan 6023 ear
So a very simple fix is to just clean the corrosion from the battery terminals inside the thermometer. You'll need a Torx T9 screwdriver (Maplin, eBay, Amazon, maybe pound shops).
11/28/2020 11:39:43 AM • Braun Health &... • Answered on Nov 28, 2020
Braun KM32 repacement beater
fixya does not sell Braun parts. Try contacting Braun for a source.
11/24/2020 7:38:26 PM • Braun Health &... • Answered on Nov 24, 2020
2answers
I HAVE A BRAUN BLOOD PRESSURE MONITOR WHICH HAS SOME LOOSE CONTACT CAN GUIDE ME TO ANY SERVICE CENTRE IN MUMBAI EMAIL
Mr Google suggests:
  1. Braun Service Centre Directions
  2. Appliance Repair Service
  3. Address: 3, 1St Floor, Navjivan Society, Lamington Road, Mumbai, Maharashtra 400008, India Phone:+91 22 2305 1554
  4. Write a review
7/15/2020 4:44:51 PM • Braun Health &... • Answered on Jul 15, 2020
How do I replace the battery in my Braun ThermoScan model HM3
1. Insert a flat head screw driver (FHSD) on the opening shown on picture. 2. While pushing down, move the FHSD towards LOT (right at this angle) as you pull towards you. The goal is to have an opening at the arch. 3. Insert another FHSD (or hard plastic if you don't want to mar) at the arch if it doesn't open. The battery orientation signs are shown on the back of the battery cover. I hope this helps. Keep fixing! braun thermoscan hm3_page_1-undefined-undefined-0.jpg braun thermoscan hm3_page_2-undefined-undefined-2.jpg braun thermoscan hm3_page_3-undefined-undefined-5_0.jpg
6/19/2020 2:19:38 AM • Braun Health &... • Answered on Jun 19, 2020
I have a Braun 9595 that I replaced the battery in. It worked for 2 shaves. After disassembling again, I found that everything works fine without the back cover. It dies with the cover on. Any ideas?
Bring it back n tellum. I had a cordless hairclip n gut a new replace cause batt had ussue. Or ucud put some electrical tape on back to keepit from shortn or groundn
4/24/2020 8:55:07 PM • Braun Health &... • Answered on Apr 24, 2020
Braun tv 33inch starts up and shuts down
https://www.cnet.com/forums/discussions/samsung-smart-tv-turning-off-609897/
3/9/2020 5:39:19 PM • Braun Health &... • Answered on Mar 09, 2020
How to replace battery for oral braun electric tooth brush
The basic method is:
  1. Dismantle handle.
  2. Desolder old battery and other connections from PCB.
  3. Remove charging coil, pressure warning light, pressure switch, PCB and battery.
  4. Replace battery.
  5. Reassemble PCB and other parts.
  6. Solder in connections for parts and new battery.
  7. Reassemble handle.
https://toothbrushbattery.com/guides/braun-oral-b-professional-care-1000-battery-replacement/
3/8/2020 5:13:11 PM • Braun Health &... • Answered on Mar 08, 2020
What does the E01 message mean on braun brewsense?
Hello, Unfortunately, E01 is an error meaning a problem with a component internally that is not repairable. Please contact the customer service team for further .
1/31/2020 12:42:19 PM • Braun Health &... • Answered on Jan 31, 2020
Braun Interface 3105 Electric Shaver Logo
2 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
fix braun series 7 razor will not charge
  • Health & Beauty
