20 Most Recent RTO Atwood Water Heater - 6 Gal LP Questions & Answers
2answers
Anode rod is stuck in atwood water heater on my
I've run in to quite a few of those the last 2 or 3 seasons, so they sure aren't fun. The odd time I have got real lucky by putting threaded plug back in, and tightening it real tight, then taking it back out and the anode took a bite to plug again and came out. Last few I did, basically had to tap it in slightly, carefully, so as not to let is drop in tank and then not be able to retrieve it. If the wire (like coat hanger size) , is still sticking out where you can get a good grip with a small pair of vise grips, then try that, and try wiggling it slightly as you pull. Last one wouldn't come even then, so I took a small drift punch and tapped wire in center, back toward tank an inch or 2, which left me a hole approx 1/8", so I threaded in a long bigger diameter screw that took a good bite to the soft metal zinc anode, then tried pulling on that as well while wiggling. Still wouldn't come, so I tapped it inward slowly, making sure I still had good grip with vise grips on screw head. Kept going in a little, then pull out a little each time as well. This one actually had to go in until it cleared opening in tank, ( didn't want that, but that was the idea of long screw, so I still had a grip on it.) but I still had hold of screw head attached and it wiggled right back out through hole after that. Most times at worst it would only have to go in about 1/2", then a good pull and some wiggling would get it out, but last one was a close call. Hope this is of some help. If explanation not clear enough, feel free to reply and ask more questions. If /when you get it out, let me know how it goes will ya?
12/10/2022 8:05:50 PM • RTO Atwood Water... • Answered on Dec 10, 2022
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
1/7/2018 4:55:06 AM • RTO Atwood Water... • Answered on Jan 07, 2018
I fill the tank up,
How are you filling the tank, and is this in an RV or what? Open pressure relief valve when filling and when water comes out pressure relief valve, you know your close to full. If it doesn't come out there when valve is open, check for by-pass valve(s) in wrong position and not filling the tank.
12/18/2017 4:07:08 AM • RTO Atwood Water... • Answered on Dec 18, 2017
My Atwood Hot Water Heater leaks when I turn the pump on.
Where is it coming from? It would make sense to have a plug in the conwe of the tank. Need you to clarify what it is lthat is leajing.
10/20/2017 7:17:15 PM • RTO Atwood Water... • Answered on Oct 20, 2017
Atwood water air pocket
No you need to replace that valve.
7/17/2017 1:21:42 AM • RTO Atwood Water... • Answered on Jul 17, 2017
I have a Atwood G6A-7
Have you changed thermocouple?
4/27/2016 3:02:08 AM • RTO Atwood Water... • Answered on Apr 27, 2016
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
4/4/2016 12:25:10 AM • RTO Atwood Water... • Answered on Apr 04, 2016
2answers
I have an Atwood 6 gallon electronic start water
Open following link for Atwood troubleshoot resources to identify product and look at manual with parts lists.
http://waterheatertimer.org/Atwood-water-heater-resources.html
Add a comment to this thread saying how you solved problem to help others who have same issue
11/3/2015 4:02:13 AM • RTO Atwood Water... • Answered on Nov 03, 2015
2answers
Gas detector fuse keeps blowing as soon as the
ANOTHER FACTORY BLUNDER. UR RV SERVICE TECH SHOULD HAVE CAUGHT THIS WHEN THEY SOLD THE TRAILER TO YOU. UR GOING TO HAVE TO FIND ANOTHER POWER SOURCE FOR THE LP DETECTOR. NORMALLY IT CONNECTS TO THE WATER PUMP WIRE OR THE HOT WIRE TO THE MONITOR PANEL.
12/15/2014 4:14:48 AM • RTO Atwood Water... • Answered on Dec 15, 2014
How can I remove a broken plastic drain plug from a hot water tank
You cn either drill it out (make sure the drill is not too big to damage the threads) and then breakit off or drill 3-4 holes in line using a 3mm drill to create a slot so a flat screwdriver can be inserted and used to unscrew it.
9/25/2014 2:47:03 PM • RTO Atwood Water... • Answered on Sep 25, 2014
How to Test g6a-8a igniter coil .
Get a service Manual!!!!!!!!!!!!!! Test voltage at slip on lead to igniter from power source. If you have Voltage @ lead within Spec values the igniter is bad and must be replaced
9/12/2014 7:03:07 PM • RTO Atwood Water... • Answered on Sep 12, 2014
My camper water heater with electronic ignition lights for a short few second burst 3 times and then times out due to heater switch inside camper..why
Sounds like it may be a dirty flame sensor. It can be gently cleaned with steel wool or scotch bright pad (not emery or sand paper). Its a small rod that sits in the flame. I believe it is part of the spark ignition assembly on your model. Only open your burner compartment though if your are certain you have the skills (and perhaps gaskets etc) to reassemble it safely. God bless
8/9/2014 10:53:57 AM • RTO Atwood Water... • Answered on Aug 09, 2014
3answers
Why does bunner light then runs for a minute shuts off then shuts off
if you haven't already ,check thermostat, check inline fuse, check ground wire.
7/2/2014 11:07:22 PM • RTO Atwood Water... • Answered on Jul 02, 2014
0answers
Not getting spark from electrode. i have replaced it and still no spark. what to try next?
igniter coil could be bad.it creates a high voltage spark across the electrode. be sure electrode is set to specs.
6/8/2014 6:18:47 AM • RTO Atwood Water... • Answered on Jun 08, 2014
RTO Atwood Water Heater - 6 Gal LP Logo
297 questions posted
Top RTO Water Heaters Experts
Mike
David Shaub
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
View Most Popular
RTO Water Heaters
  • RTO Water Heaters
Most Popular Question
remove broken plastic drain plug from
  • Water Heaters
