20 Most Recent Braun Syncro 7526 Electric Shaver Questions & Answers
2answers
Braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
7/26/2018 6:46:26 AM • Braun Syncro... • Answered on Jul 26, 2018
0answers
3answers
The base for my Braun 7526 will not lock down in
For a quick and simple solution, use a long shoe-string and tie it down.
9/19/2016 9:49:04 PM • Braun Syncro... • Answered on Sep 19, 2016
Repairing Charging cord on Braun shaver cord
no--simply because there are live wire connections to the transformer that people will touch and then seek compensation for that carelessness best if you junk it and simply buy a new charger
7/10/2016 3:20:01 AM • Braun Syncro... • Answered on Jul 10, 2016
Replace battery
This excerpt is from your manual regarding batteries. Considering the extensive battery conditioning designed into this model, I would not think the battery was intended to be a servicable part.: Environmental notice This appliance is provided with a nickel-hydride batteries. They do not contain any harmful heavy metals. Nevertheless, in the interest of recycling raw materials, please do not dispose of this appliance in the household waste at the end of its useful life. Disposal can take place at a Braun Service Center or appropriate collection sites. See link to your manual. http://www.service.braun.com/line/SH/S5493/S5493_15_NA.pdf http://www.service.braun.com/line/SH/S5493/S5493_15_NA.pdf
9/21/2015 3:01:59 PM • Braun Syncro... • Answered on Sep 21, 2015
My Shaver will not charge or turn on
Model 7526 is not a new shaver. It was made about 8 years ago. If no lights illuminate when the power cord is attached, the circuit board is bad. Unfortunately, Braun no longer makes internal parts for this model If you like this shaver model and want a similar one, you will find one at shaveroutlet.com. This model uses the same shaving head as the 7526 http://shaveroutlet.com/braun-series-1-195s-mens-cordless-shaver.html
1/30/2015 4:03:00 PM • Braun Syncro... • Answered on Jan 30, 2015
Braun Synchro 7526 Electric Shaver How do I open
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will also find compatible batteries at the link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
12/15/2014 11:59:58 AM • Braun Syncro... • Answered on Dec 15, 2014
0answers
0answers
0answers
Where can I purchase the circuit board and batteries in Johannesburg
Braun no longer supplies this type of replacement part for any of their shavers. Unfortunately, they are no longer available.
3/29/2014 1:12:59 PM • Braun Syncro... • Answered on Mar 29, 2014
How we can open braun shower to replacement battry
see shaveroutlet.com video for this at link below http://www.youtube.com/watch?v=D6jRpCnB8T4
1/20/2014 2:49:51 PM • Braun Syncro... • Answered on Jan 20, 2014
0answers
7000 series
Be the first to answer 12/27/2013 10:46:16 PM • Braun Syncro... • Posted on Dec 27, 2013Be the first to answer
Braun Syncro 7526 Electric Shaver Logo
150 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
base braun 7526 will not lock down in
  • Health & Beauty
