20 Most Recent Baofeng UV-5RA Dual Band Transceiver Questions & Answers
How do i program baofeng uv 5ra im a fire man and wanna make it scan police codes fire codes and ens codes and be able to talk to dispatch on the fire and ems codes
Hi refer to www.Milklor.com on you tube have many videos only put the model of the radio
11/12/2015 9:15:24 AM • Baofeng UV-5RA... • Answered on Nov 12, 2015
2answers
3answers
Need free chirp computer program for a bao-fang uv5ra ht to make it work
if you want it ill send it email me at [email protected] then ill send it
11/12/2015 9:10:48 AM • Baofeng UV-5RA... • Answered on Nov 12, 2015
Cannot load program to my uv5ra
ok check whats is the program firmware when you turn of press the number 3 hold annd turn on and you see BF297 or BF291 if are 291 the program is BF_5R IF NOT ARE BAOFENG NEW VIP GOOD LUCK OR GO TO MILKLOR.COM
11/12/2015 8:44:49 AM • Baofeng UV-5RA... • Answered on Nov 12, 2015
Entering code 21 on pc
check( usb all in one) program you find like this on milklor.com
3/14/2015 2:06:10 PM • Baofeng UV-5RA... • Answered on Mar 14, 2015
Manual or driver PL2303HXD or PL2303TA indesparete need of both. Scott @ [email protected] This is a uv5r bt baofeng. The drivers that come on the CD are PL2303 and will not work on windows 8.1
hi i have the same problem and i buy a other cable whith extra dierent pins (connectors) thats Works on my computer win. 8. I try to up load the program and i cant sent to me an e mail feliciano132003 at Yahoo dot com and i sent the disk of the cable to you try that
3/14/2015 1:56:49 PM • Baofeng UV-5RA... • Answered on Mar 14, 2015
Internal speaker in uv-5ra quit working is there a remedy in the menu functions to use before I open the radio?
DO YOU HAVE THE EXTERNAL MIC? first do that to now is working next if no work check with a meter for continues if you have no read is bad speaker check on youtube change speaker baofenfg
3/12/2015 4:59:26 PM • Baofeng UV-5RA... • Answered on Mar 12, 2015
2answers
I need to program my uv5ra. I have the software / drivers
Hi Jimmy,Since you have the software/drivers the problem is solved by installing same to your PC/notebook HD, once the installation is complete, you can go to the directory where you installed the software and open it, there you will find all the files and drivers. now you need to open the manual, usually in PDF format, and open it, read through it carefully to understand how your radio works, then you'll come to the section about programming your radio with frequencies, both TX and RX. follow the steps described and write down the relevant steps. Connect your radio via the cable to PC and voila! you're almost an expert. It's all about learning.Note: some software once installed will go into a setup wizard which will do what I've written, automagically.Cheers,Peter
12/28/2014 1:23:35 PM • Baofeng UV-5RA... • Answered on Dec 28, 2014
I HAVE A PROBLEM CONECTING UV5RE BAOFENG TO THE PC
you have to make sure the programming cable is fully seated into teh radio & the computer recognizes the com port that teh cable is plugged into
12/28/2014 1:19:53 PM • Baofeng UV-5RA... • Answered on Dec 28, 2014
On a baofeng uv-5ra. how do i change freqs. on channell mode? frequency mode works fine but it won't let me change the freqs. in channell mode. thanks.
You have to be in "VFO" mode. Your best bet on that extremely difficult to use radio, is to get "chirp" and the proper cable and program it via a computer. If you search on-line for "baofeng programming" you may find an alternate set of instructions. Your absolute best bet: throw that PoS away and get a Yaesu FT-60.
12/23/2014 8:25:44 PM • Baofeng UV-5RA... • Answered on Dec 23, 2014
Radio locked cant adjust
Can you hit MENU (opens the menu) 24 and MENU (opens menu item 24, Auto-lock) 0 and MENU (sets auto-lock off and confirms) EXIT Auto-Lock locks up the keyboard to prevent accidental frequency changes. It allows for transmission with the PTT.
10/8/2014 6:34:07 AM • Baofeng UV-5RA... • Answered on Oct 08, 2014
Battery won't charge
In most things I get biofeedback telling me I have either screwed something on correctly, or that I know it's cross-threaded. I know from the feel as I make the connection. With my UV5R+ and its charger stand, I really don't know if it's sitting in the charger stand and making contact -- unless I see the light turn solid red. That means it's charging. I have set it in place and it slipped right in, making the light go red. And I have set it ip place, jiggled it and set it again, and have slammed it in, all without success It is of a very poor design. That may be your problem, you have it "cross-threaded" and don't know it. Have you ever seen the battery charger show Red? I don't know if my experience is a one-of-a-kind or if it is widespread. Now, if you do get around the design flaw I have described and the charger does go red, your battery may be faulty. it's not charging.
10/8/2014 6:07:12 AM • Baofeng UV-5RA... • Answered on Oct 08, 2014
I plugged in the speaker/microphone and it will not work any solutions
I has to be for a baofeng because it is different from my older ham radio mics.
9/10/2014 3:57:27 AM • Baofeng UV-5RA... • Answered on Sep 10, 2014
How to get the "S" off the front screen
Hi,The answer my friend is throw the crappy little Chinese, mass produced Toy in the bin.If it's made in China, it's made to a price and (DUBIOUS) standard.I too got stung wth two other Chinese brands, FDC & TYT, both never lasted 3 months before things started failing.Spend a little extra, and buy a known brand, believe me, it's worth it, because when things go wrong with a well known brand (rarely), there is a wealth of info available to fix these.Sorry for the bad news.Best regards,Peter
7/20/2014 6:31:14 PM • Baofeng UV-5RA... • Answered on Jul 20, 2014
http://www.miklor.com/COM/UV_CHIRP.php#start Chirp is the best free programming software.
7/19/2014 1:34:08 PM • Baofeng UV-5RA... • Answered on Jul 19, 2014
Radio locked cannot adjust band menu or anything except fm and radio
press the lock key for more than 2 seconds until the key icon desappear,if not do a factory reset...
3/2/2014 9:52:53 AM • Baofeng UV-5RA... • Answered on Mar 02, 2014
Baofeng uv=5ra and uv-5re
One has the band limits set for the Americas, the other Europe. Thus the "a" and "e" in the model numbers.
11/5/2013 6:29:09 AM • Baofeng UV-5RA... • Answered on Nov 05, 2013
FREE HELP ON PROGRAMING THE MENU ON A BAO-FANG UV-RA5 HT
go to milklor.com
11/12/2015 8:42:45 AM • Baofeng Radio... • Answered on Nov 12, 2015
I just bought a tekoo tk-uv2 and need an english manual
Download the manual from here: http://www.manualsdrive.com/results.php?lang=en&search=TEKOO%20TK-UV2&#.VL2L5FXF_CB
1/19/2015 11:00:09 PM • Baofeng Radio... • Answered on Jan 19, 2015
I need a manual for a tk-uv2
This site lists available manuals for download: http://www.manualsdrive.com/results.php?lang=en&search=TEKOO%20TK-UV2&#.VL2L5FXF_CB
1/19/2015 10:58:54 PM • Baofeng Radio... • Answered on Jan 19, 2015
Baofeng UV-5RA Dual Band Transceiver Logo
19 questions posted
Top Baofeng Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Baofeng Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Baofeng Radio Communications
Most Popular Question
find programming software uv 5ra
  • Radio Communications
