20 Most Recent
Jet 708315LSB 10" Benchtop Tablesaw with Leg Stand and 55" Work Surface Questions & Answers
My jet table saw has excessive vibration.
Sounds to me like the arbor bearings have too much play, or one of them has failed. With the saw unplugged, see how much play there is in the blade by pushing it side to side and up and down. Remove the blade and grab the arbor with your hand and see if you can move it any direction. You should have virtually zero play. If that is the problem, major disassembly is required. If you have a pair of reasonably precise calipers and you get the bearing removed, there are several bearing distributors with good websites to find replacements pretty cheap. If only one bearing is bad you should replace both anyway. Good luck!
How do you square table saw fense?
Briefly, unplug the saw. Raise the blade as high as it will go, the fence should have some screws or bolts on the end closest to you, loosen those, put the fence up against the blade, and retighten the screws/bolts.
No power after last cut
I have seen reset buttons not work because they are full of saw dust, Take the cover off the reset button and vacuum or blow it out with compressed air, good luck, cb
Therma Overload Switch
If you have not supplied enough power (like using an extension cord) the motor sees a big voltage drop, starts drawing a lot of current and eventually overheats. Make certain to use a good supply.
JET Tools
2/5/2015 9:19:38 PM •
Jet Saws
Answered
on Feb 05, 2015
How do i adjust the blade tilt
There should be 2 handles: height and tilt. Tilt is typically located perpendicular to the blade on the base of the saw.
1/28/2015 8:38:11 AM •
Jet Saws
Answered
on Jan 28, 2015
How do i adjust a jet bandsaw jwbs-9 blade tension
You should check your manual. There's a blade tension handle on my bandsaw, which is adjusted every time I need to change tension or change blade. There ways how to check the correct tension, you can pluck the blade like a string on a guitar and if you hear music not like sound, tension is good. Or you can follow the suggestion blade tension on your saw. or you may also use tension gauge.
7/25/2014 6:53:18 PM •
Jet Saws
Answered
on Jul 25, 2014
