20 Most Recent Evesham Evolution PC Desktop Questions & Answers
Disc boot failure, insert system disc and press enter, I have no disc what to do?
that was mean the hardisk failed to boot, tried to replaced the IDE or sata gate in the hardisk and reboot the system.
10/13/2012 1:25:28 AM • Evesham... • Answered on Oct 13, 2012
I have an error message each time I boot up
is the only issue that you see the yellow 'bang?' If so; I would not worry.
3/21/2012 9:11:52 AM • Evesham... • Answered on Mar 21, 2012
I have a blue screen
this is a general error and this might be because of the operating system that is somehow corrupted. another thing is memory (RAM) of your computer is malfunctioned.
try to run memory test. if the memory looks OK then back up your files and reformat your computer
9/9/2011 12:52:53 AM • Evesham... • Answered on Sep 09, 2011
2answers
I have an Evesham Evolution desktop with Windows
It sound like you have a recovery disk not an install disk. The recovery disk you have just lets you repair windows only. If you insert the disk after windows starts and it runs you can then try to back up what you want and delete what you don't want, then run a windows repair. Its the only option, My other suggestion is to purchase Windows 7 and do a clean install.
5/9/2011 9:50:21 PM • Evesham... • Answered on May 09, 2011
First boot displayed but did not finish booting.
when you enter the computer press Del and go t bios then click load fail safe configration then click save and exit and reboot your computer if no check the power cable IDE cable or sata cable for any loose contact
4/28/2011 3:11:57 PM • Evesham... • Answered on Apr 28, 2011
Pc blue screens with 0x0000008e (0xc0000005,
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
8/5/2010 8:48:11 PM • Evesham... • Answered on Aug 05, 2010
Computer was running normally then all of a sudden
Check your power supply. Purchase a new one - and set it in place without bolting it in - if the pc comes on - you should go ahead and install and keep - it not take it back when you're sure you don't need it.
4/14/2010 7:42:02 PM • Evesham... • Answered on Apr 14, 2010
How do I find product make on evesham computer
Go to Crucial.com and run the memory detection program. It will tell you the exact make.
2/23/2015 2:58:51 AM • Evesham... • Answered on Feb 23, 2015
How do I insert a DVD in to my Evesham novatech computer, serial no. WO00966604?
CD s and DVD s have a tray that slides out of the computer. When you get the tray open place the disk (writing if any usually on the top) in the tray, and gently press it down so that it is held by the deice in the middle. Either the tray will withdraw itself into the machine after about 10s or gently pushing it towards the machine from the front will cause the tray to enter the machine. Press the windows button and with your mouse click on My Computer click on the CD or DVD item and the file might open ... To open the CD/DVD tray or drawer either press gently on the front or press the little button on the front, or else go to My Computer (above) righ click on either the CD r DVD icon and then left click on open or eject on the drop down menu that should appear 19.December.2014
12/19/2014 2:22:12 PM • Evesham... • Answered on Dec 19, 2014
Need help finding part for Evesham desktop that want connect to my tv. i have found my motherboard model which is foxconn-945g7ma, however when i search for it on the internet i find two types Foxconn
You would only be able to connect that to your TV if your TV has a VGA connector, (also called D-Sub.) There is NO HDMI or DVI connector on any 'flavor' of that model Motherboard.
4/21/2014 9:06:41 PM • Evesham... • Answered on Apr 21, 2014
My Evesham want connect with my TV
Most modern desktops have more than one video port and not all are active all the time. Try using the other ports. If that doesn't work you might have a bad video controller. You can buy a replacement video adapter which will plug into one of your PCI or AGP ports. Make sure you know without a doubt what ports your have free before buying a card there are a lot of different ports. The manual is your best bet for knowing for certain what types of ports you have.
4/1/2014 8:16:23 PM • Evesham... • Answered on Apr 01, 2014
2answers
Dual graphics card
Not just any will work but many brands will work. Take the information off of your machine at the system information window and make sure that the specs of the new card will work with all that is installed on your machine....aka, monitor, hard drive, processor, OS...etc.
3/26/2014 8:53:05 PM • Evesham... • Answered on Mar 26, 2014
0answers
W810ui1 Laptop
Be the first to answer 3/13/2014 3:12:58 AM • Evesham... • Posted on Mar 13, 2014Be the first to answer
Evesham alqem32sx
ON THEIR WEBSITE
11/3/2013 7:48:35 AM • Evesham... • Answered on Nov 03, 2013
I have had an Evesham PC desktop computer since
You might need to upgrade a few hardware items first also you might upgrade to vista then windows 8 Creating a new partition on your hard drive gives your future version of Windows 8 a place to live on your drive. Knowing exactly how much space the OS requires helps you determine how large to make your partition. Size requirements don't tell the entire story on their own, though. Other factors like drive type and additional storage help ensure you get the best Windows 8 experience where your hard drive is concerned. Size Requirements Both Windows 7 and Windows 8 have the same system requirement regarding hard drive space, so if your hard drive can handle Windows 7, Windows 8 shouldn't be a problem. For 32-bit versions of the operating system, you'll need at least 16 GB of available disk space. The 64-bit version requires 20 GB. Your partition will have to be at least one of these sizes, depending on your OS version. The PC Advisor website warns that these are literally the bare minimum requirements, and using these figures leaves you hardly any space to save files and install apps or programs. Size Recommendations You'll get more out of Windows 8 if the operating system has enough free space for you to install your favorite programs and apps. PC World calls this extra space "breathing room," suggesting you give your Windows 8 partition at least 30 to 40 GB. If you're dual-booting with another operating system or you're accustomed to keeping excess data on a separate partition, 30 to 40 gigabytes should be fine. If you'd rather have all your songs, videos and PC games on the same partition as the operating system, consider giving it substantially more space. Solid State Drive Windows 8 works on traditional hard drives with spinning disks, but it's optimized to run on a solid state drive. If you've got an SSD, consider putting your Windows 8 partition on that drive. While any operating system benefits from the speed increase an SSD brings, ARS Technica specifically recommends this drive type for Windows 8, saying the operating system's "tablet-esque feel and search-heavy usage model will be much better served by solid-state storage." Other Requirements Hard drive space is a crucial system requirement, but others are just as important. Ensuring your computer meets the other requirements before partitioning your drive for Windows 8 saves trouble in case your computer can't handle the OS. You'll need at least a 1 GHz processor that support PAE, SSE2 and NX. Your computer has to have at least 1 GB of RAM for 32-bit Windows 8, or 2 GB for 64-bit. Your graphics card must be at least a DirectX 9-capable card with a WDDM driver. Also, while you're formatting your drive, format the Windows 8 partition in the NTFS format. Storage Spaces Storage Spaces is a useful Windows 8 feature when you're working with multiple drives and partitions. The tool enables you to group drives into one larger storage space so you don't have to constantly switch partitions and explore different drives. For example, if you create a storage space between two 32 GB flash drives, you'd be able to access it as if it were one larger 64 GB drive. http://windows.microsoft.com/en-us/windows-8/system-requirements Microsoft windows 8 system requirements http://www.pcadvisor.co.uk/features/windows/3358892/windows-8-system-requirements/ PC World windows 8 system requirements http://www.pcworld.com/article/2012847/how-to-master-storage-spaces-in-windows-8.html PC World how to master storage space windows 8 http://windows.microsoft.com/en-US/windows/download-shop
9/12/2013 5:42:54 AM • Evesham... • Answered on Sep 12, 2013
Evesham Evolution PC Desktop Logo
10 questions posted
Top Evesham Computers & Internet Experts
Alexander
ADMIN Eric
ADMIN Eric
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Evesham Computers & Internet
Most Popular Question
evesham evolution desktop windows
  • Computers & Internet
