20 Most Recent Dremel & Stylus Lithium Ion Cordless Rotary Tool Questions & Answers
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
Dremel & Stylus... | Answered on May 19, 2019
My stylus is doing exactly the same thing. l was advised by numerous people to change the capacitor in the charging dock, they also said that you can find youtube videos to guide you through it (the capacitor only cost a few cents when l bought it). I really should finish doing that job, although l did actually remove the 'screws'' from the base, l warn you- they are triangle and a nightmare to unscrew, see if you can find a triangle screwdriver BEFORE you start, or you'll end up doing what l did and destroying a perfectly good straight screwdriver!??. Good luck
Dremel & Stylus... | Answered on May 15, 2019
This is the charger, its getting a reading from the battery that its charged when it isn't. I don't know exactly how that charger is wired but, to be suroe it is the charger, as I have had similar problems beforehand.
Dremel & Stylus... | Answered on Mar 22, 2019
Please help. Because l am in Australia l can't phone the tecnition and the link to get the manual doesn't go any where, neither does the dremel website, nothing happens, and every time l try to do something in this site l get catapulted back to the begining of the page. Frustrating! Can someone help me with the manual?
Dremel & Stylus... | Answered on Dec 30, 2018
Even in 2018 this is still correct. Change the Capacitor and runs OK
I have put a 50 v to make sure this never happens again
Dremel & Stylus... | Answered on Aug 30, 2018
Dremel may not be the way to go. ABS and poly plastic likes to melt and ball up on a Dremel
Dremel & Stylus... | Answered on Nov 20, 2017
Change the capacitor 220uF 25V and it will charge properly again (at least that is the result I got and several others here at FixYa).
Easy to do and cheap (component around 0,2 Euros) work about 2 min,.
Dremel & Stylus... | Answered on Jun 17, 2015
Take it back to the store, explain your problem. Like as not, they will exchange it. My experience with this tool tells me that it is a noisy unit. Depending on the material you are working and the stylus you are using, the noise will change.
Dremel & Stylus... | Answered on Dec 15, 2013
Hi Les, Dremel .com has a lot of information and a video that explains what the buttons do. Changing bits you just turn the chuck and push a button and then loosen the chuck and the bit and collet will come out.The red stuff is rouge and is used for polishing with the felt wheels and points, there is a shaft with a screw that the points are used with.I copied the owners manual but don't know if it will open.There are phone # for questions.THANK YOU for choosing FixYa.com.................Darryel
Contact the Dremel Experts for additional assistance DOWNLOADSDREMEL STYLUS™ LITHIUM-ION CORDLESS OWNER'S MANUALicon-pdf.gif
Request Literature
Submit a question
Dremel & Stylus... | Answered on Jul 29, 2011
I called Dremmel tech support FOR FREE and they told me what was broken - flex coupling between shaft and spindle. Only Dremmel model 395 type 2 and 3 have these couplings. Mailed out repair kit yesterday.
Dremel & Stylus... | Answered on Dec 24, 2009
Dremel & Stylus Lithium Ion Cordless Rotary Tool  Logo
27 questions posted
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dremel Tools & Hardware - Others
Most Popular Question
just bought dremel 1100 fully charged
  • Tools & Hardware - Others
