20 Most Recent
HP Pavilion p6716f-b Desktop PC & 20 Inch Monitor Bundle Questions & Answers
No boot - short beep, long beep (it is not a
When your computer boots up, the Basic Input-Output System
(BIOS) performs an all-systems Power On Self-Test (POST).
The POST tests your computer's most important components,
including the motherboard itself, the system's memory and the video card.
If the computer deviates from its standard beep, it may
indicate a very serious problem with your computer, or it may simply indicate
that you need to replace a system fan or a memory stick. BIOS beep codes vary
according to manufacturer.
Start your computer.
Pay attention to the number of beeps and the length of the
beeps.
There are short and long beeps.
Write down your observations.
Write down the BIOS type if this information is on your
screen.
Consult your computer documentation if you don't know what
type of motherboard you have.
Visit your computer manufacturer's support website for your
computer model if you purchased a pre-built machine.
Look up your BIOS manufacturer (AMI, Award and Phoenix,
for example) at a BIOS beep code website such as 5StarSupport, PC Hell or PC
Guide (see Below).
Match the your computer's beep code with the beep code
listing for your BIOS manufacturer.
http://www.pcguide.com/ts/x/sys/beep/index.htm
http://www.5starsupport.com/info/beep_codes.htm
http://www.pchell.com/hardware/beepcodes.shtml
Short beep long beep
1 long, 1 short beepSystem board problem
beeps.
screen.
Guide (see Below).
Hp supply central pin connected to the 19V power
- Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
- Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
- Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
- Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
- Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
Look for the driver for my Pc media center M7000 product M7682fr system number RF893AA ?
Visit the HP Support Website:
Go to the official HP support website at HP Customer Support.
Enter Your Product Details:
Enter the product name "Media Center M7000" and locate the specific model or product number. In your case, you've provided the system number RF893AA, which is also known as the product number.
Locate Drivers and Downloads:
Once you've identified your product, navigate to the "Software, Drivers, and Firmware" section.
Choose Your Operating System:
Select your operating system (e.g., Windows) and its version (e.g., Windows 7, 8, 10).
Find and Download Drivers:
Look for the drivers related to your PC's components, such as graphics, audio, network, etc. Download the required drivers to your computer.
Install the Drivers:
After downloading the drivers, run the installation files and follow the on-screen instructions to install them.
Restart Your PC:
After the installation is complete, restart your PC to apply the changes.
If you face difficulties finding the specific drivers for your model or if your PC is quite old and HP no longer provides drivers for the chosen operating system, you may need to consider using default drivers that come with the operating system or upgrading your operating system.
