20 Most Recent AUVIO Bluetooth Headphones Questions & Answers
John, probably, what would it cost to just replace and get warranty,
AUVIO Bluetooth... • Answered on Jan 11, 2017
The only way to reset your headphones is by charging them and pressing the call button and volume up and it will work like new.
this is a problem, try google search, you might find a freebie but most make you pay
AUVIO Bluetooth... • Answered on Jan 10, 2017
Your iPhone might not find the headphones if they have been previously been used with another devices. I recommend holding the call button for 3 seconds until the blue light flashes and your iPhone might find them.
While your headphones are charging press and hold the call button and volume up button and your problem is solved.
Charge your headphones and while they are charging press the call button and the volume up button and you problem is solved. After that just let your headphones charge.
AUVIO Bluetooth... • Answered on Dec 31, 2016
www.radioshack.com/.../Support/ProductManuals/3300675_...
AUVIO Bluetooth... • Answered on Dec 26, 2016
I need more details but maybe try holding the call button for 5 seconds until you see red and it will turn off.
I would advise to throw those out and if u have a xbox or xbox headphones use those
AUVIO Bluetooth... • Answered on Dec 20, 2016
Well you have to hold the call button for three seconds and the it will flash and now your phone will find the headphones and it will be successful connecting.
AUVIO Bluetooth... • Answered on Dec 14, 2016
Could be the battery has a weak charge! Try running the battery completely flat, recharge fully, then run completely flat, and repeat this cycle about 3 times......This will give the rechargeable battery a revitalised full charge! This is a good procedure for any rechargeable battery as part charging and charging when not completely flat does take its toll on a battery.
AUVIO Bluetooth... • Answered on Nov 16, 2015
I had the same issue with green light always on and not turning off. Call button plus volume up button did not work when the unit was not plugged in. When I plugged the unit in to charge, the volume up and call button (together) did reset the unit.
AUVIO Bluetooth... • Answered on Oct 31, 2015
Sounds like the rechargeable battery in the bluetooth device has failed. (Most bluetooth devices do not have batteries that are replaceable.)
AUVIO Bluetooth... • Answered on Aug 20, 2015
Contact the Company you ordered from , thet will advise you.
AUVIO Bluetooth... • Answered on Mar 16, 2015
AUVIO Bluetooth Headphones Logo
51 questions posted
Top AUVIO Audio Players & Recorders Experts
 Mikey
Mikey
john h
colinat108
Are you an AUVIO Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • AUVIO Audio Players & Recorders
Most Popular Question
send in repair
  • Audio Players & Recorders
