20 Most Recent
Price Pfister Roman Tub Hand-held Shower with Diverter In Polished Chrome Questions & Answers
Remove and replace a hand held shower head hose in whirl pool
Hey Rick........the connectors are just large nuts at each end of the hose. If you remove one of the connectors there should be a a ring slipped around a grooved part of the hose with a plate. If you remove the clip the plate should slide off enabling you to remove the hose. Let me know if you need any more help.
Thx
Ken
How to reversing stem rotation for Pfister 910-030 cartridge
For Pfister 910-030 tub stem: Take off the 1/2 white clip at the end of the post, it's next to the 12 splines that hold the handle on. Its a little tight but can be done after the stem is installed. Flip it over and slip it back on aligning the notches properly first. A 2" long 13 mm socket slipped over the end and tapped lightly with a hammer helped me get it set.
If we put the wax
If you are installing a wax (doughnut) seal to connect the toilet to the main drain, then the wax ring should be big. It should 'squish' to seal correctly. You may not need it, but I've known plumbers to install two of the seals at once for extra gap-filling. Just install the seal, sit on the toilet to compress the seal into place and then install the bolts to the floor. Done!
How to clean the screen filter in the kitchen faucet
I don't know your exact model but most faucets screen filter can be screwed off for cleaning or replacement. Remove the screen filter with a pair of pliers and a rag. Once you get it loose, you should be able to unscrew with your fingers. Put the rag around filter before putting the pliers on it to prevent gouges and deep scratches in the chrome. IF you have a dishwasher, you can clean the screen filter on top basket of dishwasher if you have one. IF the screen filter looks bad to you, just replace it. Go to any hardware store ,take the screen filter with you and get help finding the right one. Once you have a replacement, hand screw it back on as tight as you can. IF it still leaks , use the rag and pliers to tighten it just enough to stop the leak in the screw parts. Good luck.
How do I remove a Pfister Marielle metal lever handle?
Bear with me, please. Adjust the temp at the physical valve?
Interesting at the least. Never seen or heard of that. They come up with something new everyday. I'm going to follow this for my own benefit. Thank you. And good luck. - Ned
