20 Most Recent Yamaha RX-V673 7.2-Channel Network AV Receiver Questions & Answers
Yamaha Receivers have International Warranty?
Just send an E-Mail to Yamaha's customer service section. I'm certain they will be able to tell you. The only other problem you might encounter is if the USA model uses a different mains system to the one in Brazil.
6/1/2013 4:13:31 PM • Yamaha RX-V673... • Answered on Jun 01, 2013
How to set channels for stations so they are locked to my stations
You can let the Yamaha HTR-5660 set stations for the FM band automatically. To manually set the station in one of the memory banks, first tune to the desired frequency (AM/FM band). Press Memory on the receiver. The memory light will flash for 5 seconds. Press the A/B/C/D/E to select the desired memory group while memory light is flashing. Make sure that you see the colon after the letter. Use the preset/tuning left right arrows to select the memory bank (1-8) to use in that group. This also needs to be done while the memory indicator is flashing. Press Memory to save the frequency in the desired memory location. If that memory group and bank had a station frequency stored in the location, it will be erased and the new one saved. If you do not finish the procedure before the Memory indicator stops flashing, you will have to repeat the steps. You can recall the stored stations from either the remote or the receiver by pressing the A/B/C/D/E button multiple times (as needed) and the preset/tuning buttons. On the receiver, the A/B/C/D/E button is also the Next button. On the remote, it's the Menu/Set Menu button. The steps for presetting stations is shown starting on page 33 of the manual, https://www.manualslib.com/manual/197490/Yamaha-Htr-5660.html?page=37#manual . The entire manual is available here: https://usa.yamaha.com/files/download/other_assets/3/319793/01_om_htr-5660.pdf . I hope this helps. Cindy Wells
2/5/2023 10:28:11 PM • Yamaha Audio... • Answered Yesterday
Can i hook up my bose 901 equaliser to a Yamaha A S701 amplifier?
Yes, you can hook up your Bose 901 equalizer to a Yamaha A S701 amplifier. Make sure to use the appropriate cables and connectors to ensure that the signal is transmitted properly. Additionally, make sure to check the amplifier and equalizer settings to ensure that the sound is balanced.
2/5/2023 10:36:32 AM • Yamaha Audio... • Answered 2 days ago
Yamaha RX V1000 powers on fine but puts out no sound at all.
It sounds like the Yamaha RX V1000 is not properly outputting sound from the speakers. Here are a few things you can try to troubleshoot the issue:
  1. Check the volume: Make sure the volume is turned up on the receiver and on the connected source (such as a TV or Blu-ray player).
  2. Check the speaker connections: Make sure the speaker wires are securely connected to the receiver and to the speakers. Double check that the speakers are connected to the correct terminals (positive to positive, negative to negative).
  3. Check the input/output settings: Make sure the receiver is set to the correct input and that the connected source is set to output sound. Also, check the Yamaha RX V1000's settings to ensure that the speakers are set to "on" and that the correct speakers are selected.
  4. Check the mute function: Make sure the mute function on the Yamaha RX V1000 is not activated.
  5. Check the amplifier section: Sometimes, the issue could be with the amplifier section of the receiver, which can be tested by a professional technician.
  6. Check the firmware: Make sure the firmware of the Yamaha RX V1000 is up to date, if not update it.
If none of these troubleshooting steps resolve the issue, it may be best to contact a qualified service technician to inspect and diagnose the problem. They may be able to troubleshoot the problem and make necessary repairs, or advise on replacement of certain parts if necessary.
1/14/2023 10:57:52 PM • Yamaha Audio... • Answered on Jan 14, 2023
HTR-5750: How to access menu without remote control?
Unfortunately, you need the remote or a universal remote which matches the original remote to access the menus. The manual for the HTR-5750 is available here: https://usa.yamaha.com/files/download/other_assets/5/319575/HTR_5750_5740.PDF Amazon lists a few vendors with an equivalent remote. I wish that I had better news for you. Cindy Wells
1/12/2023 5:24:50 AM • Yamaha Audio... • Answered on Jan 12, 2023
Yamaha HTR-3064 A/V Receiver. It suddenly stopped responding to the remote?
Change the batteries in the remote, You wore them out.
1/11/2023 11:28:06 PM • Yamaha Audio... • Answered on Jan 11, 2023
Rx-v565 code RAV293 Yamaha remote
The codes for the AV 293 remote to operate a Yamaha RXV565 receiver may vary depending on the specific model of the remote. Here are a few steps you can follow to program the AV 293 remote to work with your Yamaha RXV565 receiver:
  1. Turn on the Yamaha RXV565 receiver.
  2. Press and hold the "Power" and "Input" buttons on the AV 293 remote simultaneously until the red LED light flashes twice.
  3. Press the "Power" button on the AV 293 remote.
  4. Enter the three-digit code for your Yamaha RXV565 receiver using the number buttons on the remote. The code may be listed in the instruction manual for the AV 293 remote or you can try one of the following codes: 431, 439, 471, 478, 559, or 678.
  5. Press the "Input" button on the AV 293 remote to test the code. If the code is correct, the Yamaha RXV565 receiver should turn off. If the code is incorrect, the red LED light on the AV 293 remote will flash twice.
  6. Repeat the above steps to try a different code if necessary.
If you are unable to find the correct code or have any difficulty programming the AV 293 remote, you may need to consult the instruction manual or contact the manufacturer for assistance.
1/8/2023 3:58:36 AM • Yamaha Audio... • Answered on Jan 08, 2023
How can I make my screen work?
There is normally a capacitor on the back of the display that may fail. They normally get dimmer until you can't see anything. Replacing it should fix it.
1/6/2023 10:35:25 PM • Yamaha Audio... • Answered on Jan 06, 2023
How do I reset the protection circuitry on Yamaha RX-A820?
press and hold the 'tone control' and 'info' buttons and press power. This will release the protect. The first thing that show on the display will be the protect code to tell you why it shut down. If it turns right back off, then you most likely have a short in the amp that will need to be repaired.
12/31/2022 11:17:22 PM • Yamaha Audio... • Answered on Dec 31, 2022
2answers
My Yamaha RX-V657 gose auto turn off after 1 or 2 second. if anyone Know about it please tell me
Probably in safe mode due to a power supply/output stage fault.
12/24/2022 1:23:32 PM • Yamaha Audio... • Answered on Dec 24, 2022
How do i reset the protection circuit on my Yamaha RXV4A?
Firstly repair the power supply fault and then the protection will reset, when there is no longer a fault.
12/18/2022 5:07:15 PM • Yamaha Audio... • Answered on Dec 18, 2022
Fixing volume control on yamaha rx596 reciever
Might be just a simple case of resoldering the joints on the Volume control.
12/18/2022 2:09:58 PM • Yamaha Audio... • Answered on Dec 18, 2022
5650 Yamaha receiver I turn it on and it just turns back off by its self
That will be a safety feature. It's clearly suffering from an overload in either the power supply or audio output stages. Either take it in for a service, or look inside (with the power off) for damage to the amp. Check the devices attached to the heat sink.
12/18/2022 12:51:01 AM • Yamaha Audio... • Answered on Dec 18, 2022
4answers
Yamaha RX-530 Stereo Receiver, LCD panel is dead but everything else works perfectly.
SADLY YOU ARE ON YOUR OWN WITH IT .REPAIR SHOPS ARE HARD TO LOCATE
12/17/2022 2:06:01 PM • Yamaha Audio... • Answered on Dec 17, 2022
Yamaha rx-v373 surround sound through HDMI ARC starts then stops. If I unplug HDMI and plug it in again, I get sound for 2 seconds then stops.
You cannot run HDMI from any source thru the Yamaha to the TV. The V661 is 1st generation HDMI headache. Version 1.1 which basically is useless. Don't blame Yamaha, it's not their fault, it's HDMI. All manufacturer's receivers prior to 09' series use either 1.1, 1.2, or 1.2a. and they all have issues. So, here's the skinny, run your audio to your receiver via optical or digital coaxial. Then run video directly to the TV via HDMI if you wish. The problem arises when you have more sources than inputs on your TV. Depending on the size of your TV can make a big difference in how you wire it. If your TV is 50" or smaller, just use component, the human eye cannot differentiate between 720p and 1080p and that's a fact. second fact, most TV shows are broadcast in a native resolution of 720p, the only real 1080p programming is on HDNET, Discovery,National Geographic and The NFL. What I mean by that is the camera used to take the actual picture is a 1080p camera. Major money! so, that being said, if your tv is larger than 50", and it's 1080p not 1080i yes, you can see a difference. If you post a comment and list all your product, I can give you the best possible way to put it all together. I feel your pain and aggrivation! I am a Yamaha, Marantz, Proceed, and Adcom Dealer. I get it from all sides! If there's anyway I can make it easier for you, I will. Hope this helps
12/11/2022 9:26:57 PM • Yamaha Audio... • Answered on Dec 11, 2022
2answers
Manual for Yamaha YST-M100
Hi, you can find the full manual on the ManualsLib website. You would just need to use the website's search to enter the product name and then the corresponding manual should show up. Thank you.
12/10/2022 4:00:47 AM • Yamaha Audio... • Answered on Dec 10, 2022
Yamaha RX-V673 7.2-Channel Network AV Receiver Logo
Popular Tags
3 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
yamaha receivers international warranty
  • Audio Players & Recorders
