20 Most Recent
Milwaukee Tool Milwaukee 18V 1/2 In Hammer Drill Kit 0627 24 Questions & Answers
Milwaukee 18v battery
No, it's showing that the battery is either not taking a full charge or the charger is not charging the battery properly. Find a Milwaukee service center, they will check them and most likely replace one or the other.
How can I fix my drill. I was drilling and it froze up on me. You can turn it one way but not the other
Place the drill bit in a bench vise with the whole machine on it together spray the chuck in with good enough wd40 and take a bench hammer and a great plastic hammer , place the angled tip side to the 3 claws of the chuck that are holding the bit and beat slowly and with care the machine from the bit some times switch inbetween the place to beat every claw of the chuck make a little time to do this but do not forget wd40 to spray after and if the machine is beat from the drill spray the whole chuck inside and try to unlock in the most cases it will function again , otherwise there must be an chuck replaced.
My drill slips under high torque
check clutch adjust,put it in drilling modecheck if speed selector is in right positionafter that if it slip aggain,you need a gearbox
I use my milwaukee in ali and pvc prep and
you would need to begin by thoroughly cleaning the inside area to remove the debris, a piece could have got under the brush not allowing it to contact the armature and shutting it down. This is where I would begin and hope that it did not burn the armature.
Milwaukke 18v l ion battery
Depends how much load and longevity you use it at. Milwaukee has a really good warranty policy. Please rate me
Slipping clutch on low switch with Milwaukee 2601-20
this tool has a 5 year limited warranty so I would try and have repaired under warranty. I looked at a breakdown and it doesn't specify how the chuck is on but I would to think it is threaded. the clutch is an assembly and there are no replacements parts other than the assembly available. Let me know if you need more assistance.
