20 Most Recent
Harmon Kardon Harman Kardon - Avr 1700 500w 5.1-ch. A/v Home Theater Receiver Questions & Answers
Audio problems
Click the link below for manual pages I mention to make changes:
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR1700_OM_EN.pdfMost dialog sound comes from the center channel / speaker. If not working correctly, it make become difficult to hear people talking especially if there is a lot of other sound going on in movies and some music, too. Check and adjust the volume level for the center channel or speaker. Check page 8 of the manual to learn how to use the remote to change the volume level of individual channels or speakers. If you want, you may find it is a good idea to check page 17 to esablish correct volume levels for each channel by runnijng the set up with the microphone. This will allow the system to be "calibrated" for the room. This is a very important step in "getting the sound right".If none of these suggestions work, you may have a problem with the center speaker itself - or with the amplifier for the center channel.I hope this helps & good luck!Check the speaker connections for the center channel. Page 6 shows the location on the rear of the amplifier - but check the speaker itself first as it is easier to get to and the rear of the amp is less likely to be distrubed and have a poor connection.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
