20 Most Recent
Poulan Pro 18 Inch 400E Chain Saw Questions & Answers
My poulan pro pp400e chain
So the chain stops and the motor still runs. Does it run at high RMP or just idles. It could be the chain brake. My clutch froze up on me after an hour of running. I had to let it cool and then take it apart to free it up.
My 18" Poulan is awsome,
When it overheats it may not be getting enoiugh oil. The oiler may be weak have it checked. I too, have a Poulan 18" Chainsaw and I think it is great. Everything I own is Poulan Pro or Troy Bilt. They are simply the best for the price.
What is the proper way to sharpen the chain
you can buy a simple kit for a few dollars, there is a jig that holds the chain and a roud file that will be guided through the jig at the proper angle to sharpen the chain
Electric Poulan Pro 400E won't run
Loosen the chain as it could have run over something or tightened itself as the chain dried out. But if it won't turn and it just humms or does' nothing the motor may have overheated and locked up. The motor may smell burnt ( like a hot elecrric stove) and it may be melted together. If its halfway new and you have the reciept you can try to exchange it but certain kinds of failures may not let you get an exchange
Poulan p3314 hard to pull and jerky
There could be a few reasons why your Poulan p3314 is hard to pull and jerky. The most common reason is that the spark plug is dirty or fouled.
This can happen if the engine is left to sit for a long period of time, or if it isn't used very often. Another possibility is that the air filter is dirty and needs to be replaced.
What could be causing your Poulan p3314 to be hard to pull and jerky?
The most common reason for a hard to pull and jerky Poulan p3314 is a dirty or fouled spark plug. This can happen if the engine is left to sit for a long period of time, or if it isn't used very often. Another possibility is that the air filter is dirty and needs to be replaced.
How can you fix a hard to pull and jerky Poulan p3314?
The best way to fix a hard to pull and jerky Poulan p3314 is to clean or replace the spark plug. If the air filter is dirty, it will also need to be replaced.
I hope this helps!
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
