20 Most Recent Omega Paslode 901000 Impulse Cordless Finish Nailer Questions & Answers
Give it a thorough cleaning.. if it still does not fire you might have to replace the spark plug.
Omega Paslode... | Answered on Jul 29, 2016
Paslode with no spark could be one of a couple of things. First, is the tool clean? These tools are notorious for failing due to the amount of sludge that builds up inside the tool from use. If you are cleaning the tool yourself, you should make sure the wires leading to the fan unit are not getting kinked or pinched during reassembly. Lastly, the tool needs a new spark unit. One way to test this out is to remove fuel and get ear close to rear of tool for a test shot. If you hear the click of the spark plug then the spark plug is fine and chances are that this tool needs to be cleaned.
Omega Paslode... | Answered on May 18, 2016
Hi Ady,
Judging by all the different batteries work in other tools, my guess is that the circuit board has failed. If you feel up to it, you just need to solder a new one in. If not you need to weigh up the cost of having done and the cost of a new tool?
Regards
Alex
Omega Paslode... | Answered on Dec 01, 2014
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Omega Paslode... | Answered on Sep 24, 2014
Has the tool been striped down and cleaned lately? And are you using genuine paslode gas? If not, do these two fixes first and try again.
Omega Paslode... | Answered on Sep 22, 2014
How old is it. Check the nail drive area to see if it is sticky etc. You may have to take it apart to fully check that out and/or to clean it and lube it. TRY spraying it with WD40 first.
Omega Paslode... | Answered on Sep 12, 2014
Yes, it is normal for the fan to run when the trigger is pulled. Does the fan start when you depress the nose?
If not, it most likely is a bent contact element, or a bad head switch.
Omega Paslode... | Answered on Oct 18, 2013
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Omega Paslode... | Answered on Jul 31, 2013
check for broken return spring under trigger.
Omega Paslode... | Answered on Apr 25, 2013
check the fuel for expiration date (on the bottom) also check for proper nail guage and for the tool being dirty and requiring cleaning and servicing. Also look for a bent safety. When it won't fire again is the driver retracted? If not it is probably dirty. Does it try to fire, you can check the spark unit before spending alot of money on it. Let me know and I will try and help
Omega Paslode... | Answered on Jul 18, 2011
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
have had the same problem! started with a noisy fan then a non responsive one. try taking out the fan assembly as per service and drop a couple of paslode lube drops along fan shaft and gently compress fan to lubricate bearing, may not be a lond term fix but hasnt stopped since and that was over 2000 2inch ago. good luck.
heatman101
Omega Paslode... | Answered on Mar 06, 2011
heatman101
Omega Paslode 901000 Impulse Cordless Finish Nailer Logo
29 questions posted
Top Omega Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Omega Tools & Hardware - Others
Most Popular Question
paslode straight
  • Tools & Hardware - Others
