20 Most Recent Stanley Tools Hammer Staple/Tacker - PHT150C Questions & Answers
On the handle press the rubber bump and fully remove by the hard plastic top of the pin
Stanley Tools... | Answered on Jun 01, 2015
The black rubber grip has two bumps near the back one is rubber one is hard plastic. Squeeze the stapler togather and press on the rubber circle to eject the pin then remove the pin by the hard plastic end while keeping the stapler squeezed
Here is a copy of the instruction manual for your stapler.
1. Press end clip in, then up.
2. Pull out spring assembly.
3. Load staples into channel.
4. Reinsert spring assembly and
snap end clip into place.
EASILY DISASSEMBLED
FOR CLEANING:
1. Squeeze stapling end of hammer
tacker together, taking care to
avoid sharp staple.
2. Remove locking pin.
3. Press end clip in, then up.
4. Pull out spring assembly.
5. Remove staple channel.
6.Clear and reassemble
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Stanley Tools... | Answered on Dec 10, 2014
First slide off the rubber grip This will expose a pin that you will need to remove. Remove the two bolts on top of the hammer with a 10mm wrench. These bolts hold the striker plate guide. Place the hammer in a vice to lightly compress the hammer head. Remove the allen head bolt located on the end of the head. This bolt holds the striker slid that strikes the staple. Remove the pin that you see that was under the rubber grip. Just tap with a punch and then you should be able to remove it with a small set of pliers. Now slid the enter assembly back just enough so that the jammed striker slid will come in contact with the striker guide face. Turn the hammer over and strike the top of the hammer on a piece of wood. This should free the slide and jammed staple. The staple and slide will come out. Take a file and deburr the slid and add a dab of grease to it. To reassemble, Attach the slide guide first, but leave it loose. The rest is reverse order. Hope this helps.
Stanley Tools... | Answered on Jul 20, 2014
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
Stanley Tools... | Answered on Sep 18, 2013
Problem is the safety micro switch. This is engaged when you press the gun against the surface. You can open the gun and short the wires. Do remember will not safety switch and hence you must ensure others know this - no children!
Stanley Tools... | Answered on Feb 28, 2013
How do I dismantle the spiral from the outer casing of a yankee screwdriver
Stanley Hand... | Answered on Sep 04, 2019
Put a little gun oil on the staples the spring that helps feed them might be catching
Stanley Hand... | Answered on Dec 30, 2014
First never take a tool apart if don't know what you are doing, second go to the Stanley web site and you can buy or download a copy of the one you need.
Stanley Hand... | Answered on Jul 25, 2014
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Stanley Hand... | Answered on Dec 12, 2013
Javid Vossough solution will not work, yes it will fire one staple/nail but then nothing as the circuitry to the micro switch is needed to return the solenoid operated hammer inside the gun
Stanley Hand... | Answered on Dec 04, 2013
I have the same sander, and cannot get parts anymore, so I carefully cut out a piece of sheet metal, and drilled holes, and put it on. so it might not say stanley, but who cares? I don't. and if it doesn't last as long, who cares. its more help than I got from stanley, who was bought out in 1973 from what I read.
Stanley Hand... | Answered on Oct 21, 2013
There will be a button to push in which will lock the spindel. After locking the spindel you need to undo a nut using a wrench or spanner.
Stanley Hand... | Answered on Oct 20, 2013
Go to Yahoo.com and type in the manual you are looking for.
Stanley Hand... | Answered on Jun 08, 2013
There is a SLOT in the end of the knife. Simply insert the strip of new blages in to the slot and you are ready to go.
Good luck. :)
Stanley Hand... | Answered on Jan 19, 2013
Push the blade out as far as it will go and hold in the button on the side while slideing blade in and out.
Stanley Hand... | Answered on Aug 04, 2012
Stanley Tools Hammer Staple/Tacker - PHT150C Logo
27 questions posted
Top Stanley Hand Tools Experts
Marvin
Marvin
efs_perpends
efs_perpends
Bill Boyd
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
View Most Popular
Stanley Hand Tools
  • Stanley Hand Tools
Most Popular Question
bht150 bostitch jammed
  • Hand Tools
