20 Most Recent Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065 Questions & Answers
The switch is probably generic.. go to a Lighting store and see if they have equivalent
Buffalo Tools... | Answered on Jul 11, 2018
There have been several factories in china that have made the motors used on buffalo generators, a couple of these are Lifan and J.D. as in Jiangdong.All of these motors are very similar to honda motors.The 6.5,13,and 15 h.p. motors are real brutes and hold up very well.
Buffalo Tools... | Answered on Mar 30, 2016
If you can't get any info from the retailer as to repairers for you machine then check out other gen sets as most run generic carbys on the engines.
Buffalo Tools... | Answered on Apr 25, 2013
That is the fun part! You have to leave the handle end free, as in no handle on it, put a good knot in one end of your new pull cord, feed it through the hole in the pulley, feeding it out so you can pull it back into the space where the pulley is. Should be a slot on the pulley to bring it up in. Wind pulley against spring, same direction as normally pulled when starting, will need three to six rounds, can't tell how many cause it varies. Stick cord out hole to where handle should be while keeping tension on spring so you don't lose it. Tie handle on and try it. You may have to adjust rounds against spring and length of cord until you get it right. Good luck!
Buffalo Tools... | Answered on Sep 26, 2012
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
Buffalo Tools... | Answered on Feb 25, 2011
I'm not familiar with this particular generator however I would suggest trying to find a local repairer to get the armature rewound, which may well work out cheaper than buying a new part anyway.
Try searching Google Maps http://maps.google.co.uk/maps?hl=en&tab=wl In the search box type in 'armature rewind' and your location
Buffalo Tools... | Answered on Jan 28, 2011
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Buffalo Tools... | Answered on Feb 05, 2010
First of all replace the on switch. The fuel tank is located on top so this unit is gravity fed. Check the inline filter for being plugged( if it has one). check the fuel line for kinks and blockages. Also check to make sure it has good fuel before starting.
Buffalo Tools... | Answered on Jan 18, 2010
Dump ALL old fuel out of tank, you might have got a clog in the fuel line, carburator, fuel valve. Remove carb bottom Sediment bowl then spray Carb cleaner thru the gas inlet AT the carb 3-4 secs CAUTION: KEEP YOUR HEAD BACK.. that cleaner hurts if you get it in your eyes... and NEVER SPRAY A HOT ENGINE (np with yours tho no start) Refill tank with NEW fuel (or strained at least if emergency remote repair) Place a suitable catch container over gas inlet line to carb (at carb) open fuel valve chk for fuel FLOWING (no dripping) into container. replace fuel line to carb start as normal
if not firing still chk that spark plug, might need cleaning now that rest is ok.
Buffalo Tools... | Answered on Nov 22, 2009
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Buffalo Tools... | Answered on Aug 23, 2009
wow, that is high, i would think voltage regulator is faulty also
Buffalo Tools... | Answered on Aug 17, 2009
try these: With air filter off see if the carb is loose at all. if it is then it is sucking air. tighten it and it shoild be fine. If it is tight there should be a screw at the bottom of the float bowl. open it and let about a half cup of fuel drain. Try it again. If it is ok then you had water in the fuel. If it still runs rough there are at least one screw on the carbs body (not the idle adjust) turn it all yhe way in and then back it out 1 1/2 turns. Try adjusting the roughness by turning the screw with the engine running. If still no joy then see if there is an in line filter change it. It may be clogged.Also try loosening the fuel tank cap. It may be causing a vacuume that is not letting enough fuel get to the carb. If these fail then remove the carb and kit it. Blow out all passeges with some carb cleaner. Then blow it dry with compressed air prior to reassembly. If this answer satisfies your question rate my answer button. If it does not, please tell me so. You are not expected to accept any answer that you are not happy with. I do expect you to let me know if you are not satisfied, and what I can do to put a smile on your face.
Buffalo Tools... | Answered on Jul 02, 2009
Do a ohm test on armature slip rings with brushes removed.You should have continuity between rings but not between either ring and shaft.
Buffalo Tools... | Answered on Mar 25, 2009
have the voltage regulator system checked
in the regulator the voltage controls the amperage allowed and it that unit is not working properly then there will be no current out put
that regulator could be part of the control board for the main ac out put and may have developed a fault in the section for 12 volts on the board
there is a limit on the charge rate for the battery and if it is exceed it may have damaged that circuit or possible blown a fuse in the amperage circuit
Buffalo Tools... | Answered on May 08, 2016
Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065 Logo
24 questions posted
Top Buffalo Tools Electrical Supplies Experts
Lawrence Oravetz
Bill Boyd
Generator Guru
Generator Guru
Level 1 Expert
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Buffalo Tools Electrical Supplies
Most Popular Question
need gas tank
  • Electrical Supplies
