20 Most Recent Bosch RotoZip Spiral Saw RZ10 - 2100 Questions & Answers
Your Rotozip may be incompatible with slate tile.
Bosch RotoZip... | Answered on Dec 19, 2017
'Sprag' the blade to stop it from rotating. Apply some WD40 or kerosene around the area and use an impact gun or impact driver to crack the nut. Check the thread and make sure you are actually turning the right way to loosen the nut. Some are a left hand thread! Cheers Bob
Bosch RotoZip... | Answered on Nov 16, 2016
righty tighty
Bosch RotoZip... | Answered on Nov 03, 2014
Try a light penetrating oil on the threads, and allow time for it to work. Sometimes working the nut in both directions, back and forth, a little at a time fill allow the penetrant to lubricate the threads better, allowing it to be more easily removed.
Best regards,
--W/D--
Bosch RotoZip... | Answered on Sep 05, 2014
Hardest part is getting the trigger mechanism back in the right position while putting the screws in place. Everything has a slot/groove it fits into before both outside covers can be put together. One side will be easier to hold the pieces while the other simply covers them. A spot of glue (elmers) may help to hold trigger in place and the wires.
Bosch RotoZip... | Answered on Apr 22, 2013
Did you ever solve this problem? Mine just did the same thing right after I put a new blade on for the first time I ever used it
Bosch RotoZip... | Answered on Feb 19, 2013
You may have to split the housing for this. I have seen where the pin can become bent or where the plastic housing becomes worn at the pin and allows it to move around too much. They usually also have a small spring with the pin which may have failed.
Bosch RotoZip... | Answered on Aug 24, 2012
Try a little PB blaster penetrating oil and a little more muscle not to much!! Nut might be a tad bit rusted in place. Good Luck....
Bosch RotoZip... | Answered on Apr 21, 2011
Bosch RotoZip Spiral Saw RZ10 - 2100 Logo
39 questions posted
Top Bosch Saws Experts
efs_perpends
efs_perpends
John Trevino
Mike
Are you a Bosch Saw Expert? Answer questions, earn points and help others
View Most Popular
Bosch Saws
  • Bosch Saws
Most Popular Question
rotozip video
  • Saws
