20 Most Recent AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Questions & Answers
Need a rebuild kit for pump not motor
A O Smith does not make a Pump, they make motors, so... what pump do you have, so pump rebuild kit can be recommended?
5/11/2015 2:44:40 PM • AO Smith 1 1/2... • Answered on May 11, 2015
I have a 1 1/2
WHAT IS THE PART NUMBER FOR THE IMPELLER AND THE MECHANICAL SEAL??
6/27/2014 7:07:09 PM • AO Smith 1 1/2... • Answered on Jun 27, 2014
Smith and jones 1\2 hp need to wire to a stamley
Try posting in the correct area. It is a pump type motor but a I have no clue what a stamley 545 automatic gate is unless it is used to block access down a path or drive.
6/18/2014 5:21:47 PM • AO Smith 1 1/2... • Answered on Jun 18, 2014
Wiring issue
Without model info, try this link. Most motor brands follow pretty standard wiring setups. Please rate me if this helps. http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
4/17/2014 12:05:54 AM • AO Smith 1 1/2... • Answered on Apr 17, 2014
Motor not working.
You need to find out what is causing the capacitor to short and "blow up or smoke". Then you will have to replace the capacitor again or the motor will never start up. Sounds like you either have a dead short or you bought a faulty Capacitor. Not uncommon for a 220+ volt Capacitor to be bad right from the factory. I replaced two Capacitors before I had a quality one, but after I replaced it twice I have had no more problems. Make sure to grease the motor through the grease fitting on it. The life of your motor depends on it.
11/9/2013 3:20:21 PM • AO Smith 1 1/2... • Answered on Nov 09, 2013
How to wire a 5 hp cap start cap run
go to a motor store
11/6/2013 9:38:27 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Two speed motor
you need to know your load
11/6/2013 9:37:43 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Need wiring diagram for 230 volt fr56j ao smith,
go on line
11/6/2013 9:36:53 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Do youy sell spa pumps? 5hp. 2 spd. 240v?
try to have motor fix
11/6/2013 9:30:16 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
2hp irrigation sprinkler pump has
be safe change the motor
11/6/2013 9:27:54 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Sprinkler motor hums, howev er impella will not start
change it
11/6/2013 9:25:20 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Pump wont prime
take to motor shop
11/6/2013 9:24:52 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
I have a 4 wire motor and a 3 wire service
if you do not know how to wire the motor get help
11/6/2013 9:22:12 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
I want to replace moter on mod# c48c89b67 how seperate moter
go to a motor service store
11/6/2013 9:18:27 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Motor running revers, counter clock wise.
GOOGEL WILL TELL YOU
11/6/2013 9:16:52 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Sprinkler pump not turning on
check ac load
11/6/2013 9:11:44 PM • AO Smith 1 1/2... • Answered on Nov 06, 2013
Motor star for few second then shut off any
check motor starter
11/6/2013 5:00:28 AM • AO Smith 1 1/2... • Answered on Nov 06, 2013
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
98 questions posted
Top AO Smith Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
View Most Popular
AO Smith Plumbing
  • AO Smith Plumbing
Most Popular Question
motor not working
  • Plumbing
