20 Most Recent Saniflo Sanibest macerator with multiple connections Questions & Answers
Bail out as much as you can through the toilet bowl. Unfortunately this is a messy job regardless and you will still need newspaper on hand.
If you lower the water level below that of the rubber gasket connecting it to the toilet though, you will be able to undo the jubilee clip holding this and slide the unit away from the toilet, hopefully without spilling much waste water.
If you can dislodge the blockage from this angle, great. If not, you might also have to take the lid off by depressing the plastic clips on each side and accessing the chamber from the top.
Saniflo Sanibest... | Answered on Sep 02, 2017
its blocked dont put paper or towles in it sorry to say its amessy job discont fromtoilet inlet have a bucket and mop handy
In U.K. Maplins, RS In U.S.A. Radio Shack Just for starters Also Google for them Simples
Saniflo Sanibest... | Answered on Apr 12, 2016
sounds as if thewater is filtring back due a possible blockage do not put paper or towles in them the water expands them a causes this problem cleaning is a messy job if they are blocked disconect from toilet connection but have a bucket and mop handy
Saniflo Sanibest... | Answered on Aug 07, 2013
Humming as in has power but appears to not be doing anything? If so, it's likely stalled because of a jam or clog. Going to have to put on some gloves etc and explore the tank for starters. My recollection is that Saniflo has all their installation, maintenance manuals online (Google is your friend ;) ). Be sure the unit is unplugged before opening up the tank! It's possible, although less likely that the clog is in the piping leading to the macerator or in the bowl, you can try a plunger also... Good luck!
Saniflo Sanibest... | Answered on Jul 09, 2011
80 percent full
Saniflo Sanibest... | Answered on Jan 27, 2011
Most likely either jammed or motor condensor blown. Depending on how confident/competant you are, you could remove the lid to expose the pump within and, after taking a deep breath opf fresh air, check that the motor turns freely - TURN THE POWER OFF FIRST!. If the motor is free to turn it points to the condensor - to this end I think you would be best advised to seek professional help.
Saniflo Sanibest... | Answered on Jan 25, 2011
Did this problem just start? Or is this a new installment?
Saniflo Sanibest... | Answered on Nov 12, 2010
if the pump is runnng but not pumping out the water then the impellor may be bad.
Saniflo Sanibest... | Answered on Sep 16, 2010
I had the same issue before. Definitely has to do with the float switch. Could be that a piece of solid is stuck at the bottom of the float switch or the membrane (black rubber piece at bottom of flat switch) may be warped/deteriorated and will need to be replaced.
Saniflo Sanibest... | Answered on Jul 20, 2010
Sounds like the pump is clogged and needs to be cleaned , or the float switch is clogged or stuck . The pumps that come with these units are under ratted and should be upgraded to a better pump. But just cleaning it out and checking the float is what needs to be done.
Saniflo Sanibest... | Answered on May 02, 2010
Faulty switch I think? This is typical of one... Or the controller spiking
Saniflo Sanibest... | Answered on Mar 15, 2010
Saniflo Sanibest macerator with multiple connections Logo
37 questions posted
Top Saniflo Plumbing Experts
Bill Johnson
Vernon Taylor
Tom Chichester
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Saniflo Plumbing
  • Saniflo Plumbing
Most Popular Question
when flush toilet spray water comes out
  • Plumbing
