20 Most Recent Lisle Serpentine Belt Tool_1 Questions & Answers
I lost my manual and is trying to find a detailed
12/29/2009 6:08:32 PM • Lisle Serpentine... • Answered on Dec 29, 2009
Need diagram for serpentine belt for dodge ram
There should be a diagram attached on the underside of the hood. Check there.
--W/D--
9/12/2009 2:04:44 AM • Lisle Serpentine... • Answered on Sep 12, 2009
My dewalt jackhammer starts for 5 seconds then stops but continues making a humming sound. It starts going again if I let go of the trigger and press it again
Maybe a thermal problem in the electronic modul and also control the powercable on a leight tensile load.
8/18/2022 8:58:28 PM • Hammering • Answered on Aug 18, 2022
Kango 950 does not hammer.motor is working, gears are ok. I have dismantled machine and cannot see anything broken
kango 950 was the hammer drill version. Usually when they stopped hammering they were due for a rebuild. These units have a aluminum piston that rides in a steel tube striker. When the 2 rubber piston rings wear out you will get the described problem. The Kango's use a special tan grease so you cannot just yank it apart and replace the 2 rings with o-rings and grease. I had to rebuild 15 900 and 950's because the previous mechanic used the wrong grease. https://project21designs.com/kango-950-parts The link sells grease & rings.
6/3/2022 2:14:01 AM • Hammering • Answered on Jun 03, 2022
Kango 950 motor runs but hammer only engages sometimes
This is an indication that the hammer needs service. When you take the barrel off you will see the striker. There is a piston inside the striker, when the rubber rings on the piston wear out you have the problem you describe. time to replace the motor brushes clean and regressed, make sure to use the correct grease, Check the backlash on ring and pinions. Don't put too much grease on the piston or it will stick and not strike. Good luck I forgot to ask which version. This is for the uk atlas coco, silver with blue or red handle
5/29/2022 2:06:56 AM • Hammering • Answered on May 29, 2022
How much is a kango 426 hammer drill
kango hammer ' Power Tools ' Gumtree Australia Free Local ...
https://www.gumtree.com.au > ... > Power Tools Find kango hammer ads in our Power Tools category. Buy and sell almost anything on Gumtree classifieds. Missing: 426 ‎' Must include: 426 Ads Kango Concrete Tools - View our Concrete Tools Here Ad·https://www.kangotools.com.au/concrete/tools Kango Concrete Tools get the job done. See our range & find your nearest stockist here. Kango has you covered for all things Concreting. View our wide range of tools here. ‎Concrete Tools · ‎Bricklaying Tools · ‎Carbide Technology · ‎Plastering Tools · ‎Drill Bits Kango hammer: Search Result ' eBay Ad·https://www.ebay.com.au/ Free Shipping Available. Buy Top Products on eBay. Money Back Guarantee! Daily Deals. eBay Plus. Returns Made Easy. Huge Selections & Savings. Fast 'N Free Shipping. Buyer Protection Program. World's Largest Selection. Make Money When You Sell. ‎eBay Tuesdays · ‎Sell on eBay · ‎The Latest Tech · ‎Home & Garden · ‎Everyday Essentials
5/5/2022 3:54:10 AM • Hammering • Answered on May 05, 2022
Cant find turmopol oil
10/15/2021 5:29:59 AM • Hammering • Answered on Oct 15, 2021
I am looking for a manual of the detroit demolition breaker 1700W
Contact the manufacturer/distributor to inquire.
3/15/2021 12:35:44 AM • Hammering • Answered on Mar 15, 2021
Where can I get a set of brushes for a kango 950X
Unfortunately, you won't find them - Kango was a great hammer, but the company has been gone for many years and there are no parts available. I would find a local repair shop that may have a different brand brush that is the same or bigger dimensions - by using a piece of 220 grit sandpaper on a hard, flat surface - you can sand them down to the proper size. It will get you out of a bind
3/3/2021 2:37:44 PM • Hammering • Answered on Mar 03, 2021
3answers
Is there any maintenance I can do on a Kango 950 Jack hammer
Ureythn GE00 is madr by Fuchs in Germany - see their website.
Darina is made by Shell - see internet for comparable grease
11/7/2019 2:23:42 AM • Hammering • Answered on Nov 07, 2019
How to troubleshoot the hammer if it vibrates excecively.... ??
no information generic answer --notify the manufacturer or owners manual for assistance
9/13/2019 6:28:41 AM • Hammering • Answered on Sep 13, 2019
Which type of oil for rok demolition hammer thank you
If an oil sight glass is in the modelrange of the brand ROK Rottela 40 , but if no sight glass is used in the model then often is to use special Grease lubrication. or only an special volume of oil and most used of them are zinc-free hydraulic based and included in the manual instructions of a maintenance set (service kit)wear parts set.
5/29/2019 9:53:04 AM • Hammering • Answered on May 29, 2019
I received my Xtreme Jack hammer 2200W Demolition Hammer. How much oil (quantity) do I put in and where do I fill it?
3 to 4 ounces for first fill. You actually unscrew the oil gauge with the little wrench that should have come with the tool and add the oil there. After putting the cap back on, hold the tool upright to check the oil level. Check daily and add oil when the level drops to 1/4 when checking as described above.
4/5/2019 5:17:26 AM • Hammering • Answered on Apr 05, 2019
My breaker won't hammer but motor running
You need to check armature gear it can be damaged. Connection rod can be broken or you just need new o-rings and grease
2/9/2019 7:50:17 AM • Hammering • Answered on Feb 09, 2019
2answers
My onan diesel genset won't start after almost running out of fuel stopped it added more fuel now it won't start
Could be vapor locked. Prime the line and try again.
9/27/2018 8:54:14 AM • Hammering • Answered on Sep 27, 2018
Can you tell me how to repair a spring in trigger switch in kango 950
Buy a new switch the old switch was modificated by an maintenance kit if you have an old blue or red real Kango from England. or black Atlas Copco . But if you have the red Milwaukee Kango then there is only a new switch to replace.
8/28/2018 4:11:18 AM • Hammering • Answered on Aug 28, 2018
Switch for kango 950 S
  1. The total condition of the seal anvil piston and striker are very important for the total condition of impact when spending a service kit (maintenance) when there is leakage at the front part everything will be hot inside and the rings will harden again quickly.
kango 900 950 round switch housing
8/16/2018 7:56:48 PM • Hammering • Answered on Aug 16, 2018
Kubota ASK-R150 Generator
There is no question here
8/3/2018 9:49:16 PM • Hammering • Answered on Aug 03, 2018
Lisle Serpentine Belt Tool_1 Logo
5 questions posted
Top Lisle Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
View Most Popular
Lisle Hammering
  • Lisle Hammering
Most Popular Question
lost manual trying find detailed
  • Hammering
