20 Most Recent Generac 5724 GP Series GP3250 Portable Gas Powered Generator Questions & Answers
FRIST O FALL CHECK TO SEE IF THERE IS A SHUT OFF VAULVE UNDER THE GAS TANK SEE IF THIS IS OPEN ALSO HOW OLD IS THE GAS , DONT LEAVE GAS IN THE GAS TANK THE GAS TODAY DOES NOT HAVE BUT A MONTH OF SHELF LIFE. YOU MAY HAVE TO PULL THE CARB DOWN AND CLEAN THE BOWL AND THE JETS IN THE CARB ALSO START BY PUTTING FRESH GAS IN THE TANK
Generac 5724 GP... | Answered on May 22, 2014
First you need to identify, is there a spark at the plugs? Is there fuel getting the cylinders, it can be so many things until you define at least that, the solutions are too many to list
Generac 5724 GP... | Answered on Nov 18, 2013
Throttle advance issue, Check the carb.
Generac 5724 GP... | Answered on May 19, 2013
this should show you everything you need to see www.lawn-mower-shop.com/carb1.htm
Generac 5724 GP... | Answered on Aug 04, 2011
Hi and welcome to FixYa, I am Kelly
Here is the diagram for the 4613 prior to the G series
http://www.milwaukeetool.com/CMS/Diagrams/58-01-0960.pdf
G series
http://www.milwaukeetool.com/CMS/Diagrams/58-01-0961.pdf
There are 3 things that can cause no power at the outlets.
1. Brushes are worn (remove the end bell and the brush block. Inspect the brushes for uneven wear.
2. The AVR has failed. This is a very simple regulator consisting of 1 capacitor and a diode. Inspect the cap and diode for any obvious signs of damage. Most of the time the capacitor bulges or burns out.
3. The armature commutator is very dirty. Clean off with sand paper by rotating the engine with the spark plug removed holding the sand paper in one place until the armature commutator is a shiny copper color.
4...... There is a possibility fo wiring damage or stator winding damage but.... unless you were operating the unit under a heavy load for a long time.... I doubt the stator has failed.
I think your going to find either a bad set of brushes or a problem with the AVR. Most of the time the AVR can be repaired by just changing the capacitor.
Thanks for choosing FixYa,
Kelly
Generac 5724 GP... | Answered on Apr 27, 2011
Why don't you keep it open?
Generac 5724 GP... | Answered on Jun 08, 2010
There should be a "full wave bridge" which consists of three diodes that converts DC to AC. Try your local alternator shop before taking it in to a certified repair center.
Generac 5724 GP... | Answered on Jul 10, 2009
Go online to Generac and they have parts list and owners manuals online. They will ship you parts.
Generac 5724 GP... | Answered on Jun 29, 2009
Regarding the advice about "Flashing" a generator.
Do you people even know what that means?
What you are doing is messing with the capacitor that is part of the voltage conversion. Likely you are burning any shorts out of the capacitor. Has noting to do with the fields or coils or rectifier.
So if you are having issues then test the capacitor and replace it.
Try your flashing and see if you don't fry the rectifier.
It amazes me that people will blindly follow something they don't understand "hoping" that something good will happen.
But if a new generator is what you want then give your old one away instead of trashing it.
Generac... | Answered on May 13, 2020
During engine cranking and operation the controller receives AC
voltage and frequency signals from the ignition magneto via Wire
18. Should the speed exceed approximately 72 Hz (4320 RPM),
the controller's logic will de-energize the "run relay" (internal to
the controller). The relay contacts will open terminating engine
ignition and closing the fuel shutoff solenoid; the engine will
then shut down. This feature protects the engine and alternator
against damaging over speeds. During cranking the RPM signal
generated by the magnetos is used to terminate engine cranking.
Generac... | Answered on May 09, 2020
If you have a Generac Generator which fails to start during a power outage and gives an Error Code 1518 - RPM Sense Loss you can try and manually get the generator restarted very simply. ... The generator should wait 5 seconds and then try and auto-start up to 3 times.
https://www.justanswer.com/small-engine/bwmwi-working-generator-generac-protector-qs-38kw.html
Generac... | Answered on Mar 25, 2020
it is not producing voltage...
Generac Air Cooled Generators - Ziller Electric Inc ' Interactive Generac Generator Forum
https://www.google.com/search?q=generac+overspeed+fault&rlz=1C1OKWM_enUS816US816&oq=generac+overspeed+fault&aqs=chrome..69i57j0l6.5183j0j8&sourceid=chrome&ie=UTF-8
Generac... | Answered on Mar 11, 2020
i suspect you need a new controller. try asking here. read the rules before posting https://www.zillerstore.com/?forum=705132
Generac... | Answered on Dec 18, 2019
If you want to have a new diesel generator set in future, please visit the website for your reference: https://starlightgenerator.en.made-in-china.com/
Generac... | Answered on Dec 10, 2019
Generac 5724 GP Series GP3250 Portable Gas Powered Generator  Logo
13 questions posted
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Generac Electrical Supplies
Most Popular Question
milwaukee generator gas engine runs but
  • Electrical Supplies
