20 Most Recent Pramac Storm 5000 Watt Generator Questions & Answers
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Pramac Storm... | Answered on Sep 20, 2009
Adjust engine speed
Pramac Storm... | Answered on Sep 18, 2009
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Pramac Storm... | Answered on Jun 29, 2009
If you need data of valve clearance gap of the diesel generator, you can check on the operation and maintenance manual. If still can not find, try to ask your supplier whom supplies the diesel generator to you.
If you need to have a generator set in future, please refer to www.dieselgeneratortech.com.
Pramac... | Answered on Jan 06, 2020
The air duct is blocked by dust and the ventilation is poor, which makes the heat dissipation of the generator difficult. The dust and oil dirt in the air duct shall be removed to make the air duct unobstructed.
Pramac... | Answered on Dec 21, 2019
Please see the operation manual.
If you have plan to purchase a new diesel generator set in future, please visit at www.dieselgeneratortech.com
Pramac... | Answered on Dec 05, 2019
You can changes to Auto mode.
Some generator has auto mode and manual mode. In generally, emergency generators have these two actions, when power grid is cut off, the generator will connect to machine automatically, then supply power to the machine.
If you need diesel generator set or more support, please visit at www.dieselgeneratortech.com
Pramac... | Answered on Oct 12, 2019
I don't know your equipment, but the unbalanced term may refer to too large a load connected to one leg of your split phase service. Go to your load panels and try to get the amps drawn by your loads to be more equal. You may be over taxing one leg and have available capacity on the other, assuming you are running a 110/220 V split phase output.
Pramac... | Answered on Mar 15, 2019
website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
Pramac... | Answered on Feb 08, 2019
portable generator head stoped making power engine runs fine sircut brakers are fine
Pramac... | Answered on Jan 29, 2019
by finding the problem --check oil and circuits
Pramac... | Answered on Dec 11, 2018
Try Googling (Pramac)(P6000s)(manual) without parens.
Pramac... | Answered on Mar 22, 2018
Pramac Storm 5000 Watt Generator Logo
Popular Tags
11 questions posted
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Robert Wooley
Robert Wooley
Ngoro
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Pramac Electrical Supplies
Most Popular Question
oil change
  • Electrical Supplies
