20 Most Recent Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Questions & Answers
If selled some capacitor or new ignition parts order it always with statement of the serial motornumber and the year of build , because of modifications on marketing technical dicisions can be made for your engine, that can prevent a next disappointment. may be for the problem a new sparkplug the supression capacitor can also be bad a bad sparkplug connection cable .are some small sugestions.
Briggs &... | Answered on Mar 01, 2018
sparkplug or a defect ignition coil, if the last option happens it is a very important that you should always note the serial number and year of age and the brand of the used engine because of marketing technical modifications can happen over time.
it happened in practice too often that some people just give up the model and then come to decide that there is no spark coming from the spark plug.
Briggs &... | Answered on Feb 25, 2017
it should be right below the link to the choke rod
if not what is the engine number
Briggs &... | Answered on Aug 02, 2016
pull the bulb and retaing ring any way you can. don't try ti save them. you get a new retaing ring with the bulb. put the new bulb in then work the retaing ring in with a screw driver,clean everything behind the bulb before you put the new on in.
Briggs &... | Answered on Nov 27, 2014
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Briggs &... | Answered on Jun 12, 2014
Maybe your converter is stopped up this is just one thing could be a fuel filter
Briggs &... | Answered on Feb 09, 2014
That is never good....
Briggs &... | Answered on Sep 11, 2013
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
149 questions posted
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
JOHN LAPIER
John Trevino
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Hammering
Most Popular Question
condenser 8 hp briggs engine corroded
  • Hammering
