20 Most Recent
Cuisinart DLC-1SS Mini Prep 2.63 Cups Food Processor Questions & Answers
My cuisinart DLC-1ss will not
The bowl must be locked in the correct position for the unit to turn on.
Remove the bowl, place on unit and rotate into place.
10/4/2010 5:40:31 AM •
Cuisinart...
Answered
on Oct 04, 2010
Safety pin on food processor won't retract
It sounds like the safety interlock system on your Cuisinart 14 cup food processor is engaged, preventing the bowl from fitting securely onto the base. Here are some steps you can try to resolve the issue:
- Unplug the unit from the electrical outlet.
- Use a small, pointed object such as a toothpick to gently push the white safety pin up and out of its locked position. This may take some effort.
- Check the base of the food processor for any obstructions or debris that may be preventing the bowl from fitting correctly. Clean any debris you find.
- Reinsert the bowl onto the base, ensuring that it is properly aligned and twisted into place.
- Press the bowl down firmly onto the base until you hear and feel it click into place.
- Plug the unit back in and test it to see if the safety interlock system has been disengaged and the food processor is working normally.
If these steps do not resolve the issue, it may be necessary to take the unit to a professional repair technician or contact Cuisinart customer service for further assistance.
Cuisinart Food Processor (14 cup
For cuisinart food processors that won't shut off: with bowl off - not attached - hold OFF button down while plugging in. With a screwdriver or other implement, press the button that gets depressed on motor base when bowl is attached and snapped into place ( small flat rectangular piece that clicks the bowl into place. While still pressing OFF button, press this a few times times, unplug then release the OFF button. I tried several suggested combinations of button pushing and unplugging, and this seems to have fixed it!
My Cuisinart food processor will not start. I have only used it a couple of times.
Hello, Sally -Make sure you have the work bowl properly placed on the base and the lid properly attached to the work bowl. I often have trouble getting the work bowl inserted in the base of our food processor and also have trouble getting the lid fitted into the bowl properly.Since I have no idea which model of Cuisinart food processor you have, I am unable to advise you further.You can contact Cuisinart Product Assistance:US toll free number:800-726-0190Monday to Friday, 8:00 AM - 10:00 PM (Eastern Time)Saturday and Sunday, 9:00 AM - 5:30 PM (Eastern Time)Best wishes.
Don't throw out your Cuisinart-Keurig SS-700 if the switch is broke.
Would you pay $1.84 to fix it? Cuisinart does NOT carry the #1 part most likely to fail, the on-off rocker switch. Most of the parts they do carry you'd only need if you were careless and broke the item, but the switch gets daily use and these snap-in switches are not made to last to begin with. The switch is not listed on their web site and if you call they will tell you it's time for you to buy a new machine. If you are a handyman to the extent of having a solder iron and a Phillips screwdriver then the switch can be bought from a commercial electric/electronics supply house. The shipping costs seven times more than the switch, and much more if you want air freight. The switch itself is $1.84. It's a medium task and will take about 30 minutes tops. The most time taken was 7 days waiting for the normal shipment to arrive. It's PN 15N8920 from Newark Element14 @ "https://www.newark.com/". They are a wholesaler and I didn't volunteer that I wasn't a contractor or business. In the online order form when it asked for company I filled in "Retired" and I answered all the other application form questions they had so I could return there again I needed something they carried. Their form didn't ask if I was a re-seller and my answer would have been "no" but if it had gone down that rabbit hole I may not have been able to order. In my order I bought two of the switches; by the time my SS-700 fails and needs another switch I'll probably be glad I bought the backup. For Cuisinart not to carry that switch is planned obsolescence IMHO. Yes, a homeowner who is not handy with some basic tools might be unable, but even a small town repair business might not go through the trouble I did because they'd have to pay and pass along to you the $20 (90% for shipping)for the part, and by the time they add on a reasonable charge for labor your bill would probably be $70-$90. Facing that amount you might think buying a new one is best for you, you'd get all new, the latest, including a warranty. Imagine if an Ace Hardware or Home Depot carried that switch (I looked), I'd have had it working the same day. Keurig could buy a higher quality switch to manufacture with, but there's more revenue for them going the way they are now, and this planned obsolescence every product maker uses puts more permanent waste in our landfills.,
