20 Most Recent Craftsman 1/2" Impact Wrench Questions & Answers
If you are trying to loosen or tighten a bolt or nut the the impact just stops more than likely there is a problem in the hammer (clutch) mechanism (items# 24 through 30), there could be broken part causing the mechanism to jam, the hammer (clutch) needs to hit and then slip to let the motor turn as they are directly coupled (no gears). On the flip side in the motor there are vanes (blades)
(item# 17) that need to have free movement and could also cause a condition were the motor could have low power or cause a locked condition.
Follow this link for the owner/parts manual:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Craftsman-Parts/user-manuals/manual-downloads/Model-875198641/0247/0755200?modelNumber=875198641&diagramPageId=&documentId=P0710197
Craftsman 1/2"... | Answered on Jan 22, 2015
MOST AIR TOOLS ARE DESIGNED TO RUN @ 90 P.S.I.
Craftsman 1/2"... | Answered on Nov 28, 2014
buy a better gun the cheap ones dont have any power
Craftsman 1/2"... | Answered on Jun 27, 2013
you can download this from www.searspartsdirect.com
Craftsman 1/2"... | Answered on Apr 28, 2013
I found these posts when looking for a repair kit or parts for my Sears 756 CP. Appears I need the fastest moving most common to fail NLA part. Had this gun since new. Used for years in the shop then put it in the bottom of the tool box when the valve went out years ago.
In a clean up round I pulled it out to make the decision fix or recycle. One of those not wanting to throw out a perfectly good impact I started looking for parts. I did order a valve from a 744 and will be trying it. Since the shaft is shorter I was going to use the shaft from the 756 and cut it to make up the difference. Do not know yet if this will work.
In the mean time I started looking through one of the spare hardware drawers and came across a oil metering valve seat from a rotary engine. It fits rather snugly on the actuator shaft from the 756 and with a washer works. It is basically a jet encased in rubber.
This 756 is back up and impacting well. So if any one is still looking for the throttle valve for your 756 I can provide you with something that will work. Do not know what the life expectancy will be though. Since this will not be the everyday gun should last for a while.
Mazda part numbers that should work N236-14-633A - N326-14-633
Craftsman 1/2"... | Answered on Aug 15, 2012
there is a neoprene O ring in the trigger area ,that breaks down ,it needs a service by an air tool repairer ,it is not expensive. dont use wd40 or the like if dont have airtool oil use auto transmission fluid and this wont happen too often
Craftsman 1/2"... | Answered on Jun 06, 2012
check the specs and make sure your not pushing it harder than it was built for.
replace the brushes
Craftsman 1/2"... | Answered on Apr 15, 2012
how much oil did you put in? you are only supposed to put a few drops in the air hose coupler.
Craftsman 1/2"... | Answered on Aug 21, 2011
Craftsman 1/2" Impact Wrench Logo
44 questions posted
Top Craftsman Air Tools & Compressors Experts
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Air Tools & Compressors
Most Popular Question
craftsman 1 2 inch air impact
  • Air Tools & Compressors
