20 Most Recent Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Questions & Answers
My burr grinder also stops if the ground spout (where the coffee shoots out) is clogged. I use my grinder for an espresso machine so i always have the setting on the finest and so with the oils and the fine grind it clogs this spout pretty often. I"d check yours out too (ie remove the coffee ground bin and you can see the spout. If it is clogged uplug the machine and take a tooth pick and un clogg it. Don't jam the tooth pick in there to deep you don't want it to get shuved into the grinder wheels.
Cuisinart... | Answered on Oct 22, 2020
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Cuisinart... | Answered on Jul 05, 2018
We are on our second and last machine; after this DBM 8 goes out, I am going to find the most basic grinder I can and stick with it. That said, I fixed ours by removing the clear plastic reservoir where the ground coffee ends up, and then removing the build-up of coffee grounds around the exit chute where the ground beans enter the reservoir.
So, slide the reservoir out, just as you would when emptying it in to your coffee maker and set it aside. Have a flashlight ready when you tilt the grinder forward. On the back side you will see the hole where the ground beans empty into the reservoir. Take a toothpick and get rid of all the clay-like coffee reside that has built-up around that hole. Use a can of dusting air, if possible, (the aerosol "can" type used to blow dust particles from your computer) and blow away all possible ground coffee residue in the hole and around it. This will allow the reservoir to seat snug and flush again. This process fixed ours and I don't know why for sure, other than I suspect, the clay like build-up of coffee grounds, over time prevents the reservoir from seating properly and it has to seat perfectly to work. Good luck.
Cuisinart... | Answered on May 21, 2018
MY DBM-8 CRUISINART WILL NOT GRIND COFFEE BEANS THE
Cuisinart... | Answered on Feb 19, 2017
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Cuisinart... | Answered on Jun 27, 2016
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Cuisinart... | Answered on Feb 20, 2015
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
67 questions posted
Top Cuisinart Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
KBeaN1
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Cuisinart Coffee Makers & Espresso...
  • Cuisinart Coffee Makers & Espresso...
Most Popular Question
coffee grinder not working
  • Coffee Makers & Espresso Machines
