20 Most Recent RTO Weller D550 Soldering Gun Questions & Answers
You need to adopt an on-off-on---- action to control maximum temperature. Try to keep the tip so that the solder flows properly, but the tip doesn't try to burn up. Hope this helps!
RTO Weller D550... | Answered on Jan 08, 2011
You have sufficient reason for returning the gun to the dealer. Good luck!
RTO Weller D550... | Answered on Aug 11, 2010
are you sure you bought the H.D. tip this is the big gun
RTO Weller D550... | Answered on Jul 28, 2009
Heat gun tips often get bad electrical connection where the nuts tighten to the tip ends. Remove the tip, clean the ends, re-install the tip, making sure the nuts TIGHTEN onto the tip ends. Your problem is common and always caused by a poor connection at the tip ends/nuts.
RTO Weller D550... | Answered on Jun 22, 2009
The bulb you seek is a type222 2.33v 270mA bulb available from Radio Shack p/n272-1124.
http://www.radioshack.com/product/index.jsp?productId=2102806
RTO Weller D550... | Answered on May 04, 2009
There is a resettable breaker inside the machine that cuts off power to the plasmahead when tripped. Check that and make sure the head is secore to cable and cable is secure to machine.
If it still fails to function check the coil in the contactor to make sure it has not burned out. Also check the pressure switch to make sure it closes contacts to make the circuit when the unit is pressurized If switch is not functional the head will not operate. Also check gas solenoid or solenoids to make sure they do not have burned out coils as well. An Ohmmeter should show about 2000 ohms give or take some. The main contactor winding also. It may be the main contactor needs replacement- a loose power connection can lead to burned contacts. So if you hear the machine click when you press the trigger, but no power to head, and all the other items mentioned still leaves you with no power at the head, that main contactor is the likely culprit.
If IGBT's had failed- they would blow apart part of their plastic case.So a quick visual is usually adequate for those.
RTO Welding... | Answered on Sep 27, 2012
A micro welding torch should be a smaller version of a full size welding torch - identical apart from size. It is most important a user thoroughly familiarises himself or herself with the correct usage and safety precautions because failure to observe the correct procedure can result in extreme danger. A flashback can have potentially serious consequences...
A person who is thoroughly conversant with the procedure and safety will know how to connect the hoses to the welding torch and to the cylinders - if it is a quality unit, it is an intuitive process due to the fuel gas fittings being left hand thread and the oxygen normal or right hand thread and the hoses are or should be different colours with blue being the norm for oxygen and red or orange for the fuel gas.
One final word - never, ever, under any circumstances use a lubricant on the threads of the oxygen bottle or associated fittings...
Welding Tools | Answered on Dec 26, 2020
A great many older home mig welders were produced with a live torch, ie. the manufacturer had saved the cost of the contactor, the high current electromechanical relay that switches the welding current on or off in response to the torch trigger...
It was inevitable some manufacturers would replace the rectifiers and contactor with thyristors (SCRs) and obtain both functions from a single modification.
The trigger switch controls the wire motor and the contactor so if the wire motor is working ok it is unlikely the fault is there and if your welder has a contactor it could be stuck or a wiring fault has caused the coil to be permanently energised or if your welder uses the solid state version, either one or more of the thyristors have failed or a circuit fault has caused the supply to the gate to be permanent causing them to be permanently switched on.
Welding Tools | Answered on Dec 22, 2020
If you need plasma cutters visit this site
https://plasmacuttershub.com
Welding Tools | Answered on Dec 02, 2020
This is one is a common issue you have to read the tig welder guide and I am sure you will find something. https://myweldingyard.com/best-tig-welder
Welding Tools | Answered on Nov 11, 2020
Contact Mastercraft directly to inquire.
Welding Tools | Answered on Nov 04, 2020
RTO Weller D550 Soldering Gun Logo
5 questions posted
Top RTO Welding Tools Experts
Bill Boyd
ray gallant
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
RTO Welding Tools
  • RTO Welding Tools
Most Popular Question
new weller d550 screw missing
  • Welding Tools
