20 Most Recent Hobart Champion 10,000 All-in-One 10,000-Watt AC Generator and DC Welder with Robin Engine #500433 Questions & Answers
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Hobart Champion... | Answered on May 12, 2020
Lots of torches are fairly universal and you are likely to find it cheaper to replace only the parts needed if you can find them - manufacturers tend to prefer to sell the torch (or gun) complete with the hose, cables and sheath and they are expensive though considerable savings can be made dealing with factors or independent supplier/repairers.
Most professional mig welders over here use the euro torch and when a welder doesn't have one and the torch is ready for replacing it is a worthwhile modification, especially if the necessary parts can be sourced secondhand or salvaged.
The euro torch just plugs into the machine and once the machine has been modified there are plenty of usable secondhand ones about that can be had for a song.
If you aren't conversant with the euro torch, try a search...
Hobart Welding... | Answered on Oct 05, 2019
Is it 220 vts ? If so, Check the outlet with a voltmeter to see if you have 110 vts. On both of the top terminals .
Hobart Welding... | Answered on Jul 12, 2019
It sounds like a relay is stuck closed. It could be on the control board. Call Miller welding and give them the model number and they will be able to help . Good luck
Hobart Welding... | Answered on Jun 16, 2019
It’s close enough not to be able to answer that. The inrush current of a welder is huge anyway, so it could exceed the instantaneous capacity of the generator. However, it’s also possible with capacitance in the welder to smooth that out, that it will work fine. The only way to be sure is to test it. If you can’t do that before purchasing, it’s a risk you take. On balance it should work, but may not.
Hobart Welding... | Answered on Feb 06, 2019
Return it for another on or call Hobart customer service. Number is listed in the instructions that came with unit. Page 7-7
https://www.tractorsupply.com/static/sites/TSC/downloads/ProdContentPDFs/1021027_Man1.pdf
Hobart Welding... | Answered on Feb 01, 2019
Request the wiring diagram (not schematic) directly from Hobart.
Hobart Welding... | Answered on Jan 10, 2019
Hobart Champion 10,000 All-in-One 10,000-Watt AC Generator and DC Welder with Robin Engine #500433 Logo
5 questions posted
Top Hobart Welding Tools Experts
David Soto
David Soto
Bill Boyd
Tom Chichester
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Hobart Welding Tools
Most Popular Question
hobart champion 10 000 welder generator
  • Welding Tools
