20 Most Recent Mtd LAWN MOWER PART # 791-180705 Assembly, 13.5" 135 GU Questions & Answers
Hi ! I have the same mower. It is an older machine and possibly the belt that drives the mower is worn. The belt drive is spring loaded and when you engage the mower by lowering the lever, aspring pulls the deck backwards against the blade. If the belt hasn't been replaced in a while, I would start with that first.
Mtd LAWN MOWER... | Answered on Apr 20, 2010
Most Mower engines have an oil drain plug located at the base of the oil fill tube or dip stick tube, Most mower engines use a standard 30wt engine oil, however, to stay within the parameters of your warranty, use the manufacturers reccommended oil, this info can be located in your owners manuel.
Mtd LAWN MOWER... | Answered on Apr 14, 2010
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mtd LAWN MOWER... | Answered on Apr 03, 2010
Im sorry the number you have posted is NOT a valid number
Mtd LAWN MOWER... | Answered on Oct 22, 2009
the lift spring is the spring that attaches to the deck handle that lifts the deck up and down. i can see in the manual where to attach one side, but it does not give detail where to attach the small side. The lift assist spring will connect from the lever base connect point to the very rear of the tractor
https://www.shopyourway.com/questions/1090200
https://www.youtube.com/watch?v=HDdTIH9uBuQ
Mtd Garden | Answered on May 19, 2020
You might want to look for any broken gears where the chute pivots and anything that might be bent not allowing for any total movement. Plus check to see if the gears are making contact.
Mtd Garden | Answered on Apr 02, 2020
You might be able to find what you are after here >> https://www.mtdparts.com/en_US/ari-partstream.html <<
Regards
Geoff
Mtd Garden | Answered on Jan 07, 2020
not adjusted correctly -wrong cable -wrong belt on deck
Mtd Garden | Answered on Oct 08, 2019
Check with SearsPartsDirect.com if they cannot answer try eReplacement Parts.com
make sure the vent in the gas cap isnt plugged up. test by loosening it a bit to see if it cures your problem
Mtd Garden | Answered on Oct 07, 2019
sounds like the drive belts may be wore out and need replaced. also the tension pulleys may be binding. clean and spray some lubrication spray on them that may help some.
Mtd Garden | Answered on Sep 20, 2019
Request the wiring diagram directly from Huskee.
Mtd Garden | Answered on Sep 19, 2019
Dont know the exact lash for the MTD OHV engine but most small engines of this type will work just fine with both intake and exhaust at 0.006 inches. Make adjustment with piston at TDC compression stroke.
Hi Nick,
This may be the same diagram you already have, but this is the manufacturer engineering drawing for that deck.
MTD 13RN771H729 Yard Machines Lawn Tractor 2007 Home Depot Deck Assembly...
Mtd Garden | Answered on Aug 27, 2019
Mtd LAWN MOWER PART # 791-180705 Assembly, 13.5" 135 GU Logo
9 questions posted
Top Mtd Garden Experts
Dennis Key
Dennis Key
dannydoesita
Marvin
Marvin
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
18hp 42cut power kraft deck probleme
  • Garden
