20 Most Recent Kwikset Brz Sgl Cyl Deadbolt Questions & Answers
sometimes the kwikset web site has templates that you can download
Kwikset Brz Sgl... | Answered on Jun 17, 2011
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Kwikset Brz Sgl... | Answered on Jan 10, 2010
easy one this ,get a battery drill ,HSS drill bit and just drill the barrel out takes about a minute ,then when you get to the end of the lock ,do not go any further just pull the lock barrel out and put a screwdriver in and turn the slot at the bottom and the door will open .Do it often here when tourists loose the key on the beach or have bag snatched or pick pocketed and the spare key is in the UK .
Kwikset Brz Sgl... | Answered on Jan 02, 2010
Did you cut the bar to the correct lenght?(the flat or square one that connects to the thumb latch or other cylinder?) Too long and you'll bind the lock.Good Luck
Kwikset Brz Sgl... | Answered on Sep 15, 2009
It is not removable, it a knob.
Kwikset Brz Sgl... | Answered on Sep 14, 2009
A really, really, REALLY sharp chisel can be used to pierce the steel door skin enough to form the mortise you need for the bolt plate. Do not use a wood chisel unless you never ever intend to use it on wood again or have the means to completely renew the cutting edge. Cutting the opening for a plate in a metal door jamb is another issue since it is probably too thick to yield to a chisel. If the jamb is 1/8 to 1/4 inch thick you can just drill a hole in it to accept the extended bolt. it will be just as strong as a plate (maybe stronger.)
Kwikset Brz Sgl... | Answered on Jul 29, 2009
on the deadbolt yo should be able to turn it over, but on the door knobs and handle sets, you are stuck with it
Kwikset Brz Sgl... | Answered on Jul 11, 2009
tighten the two screws on the inside of the door phillips screwdriver
Kwikset Brz Sgl... | Answered on Jul 08, 2009
Tighten all screws on lock to a firm tightness. DO NOT OVER TIGHTEN as to bend the lock casing! Snug only. Use powered graphite to inject into lock and add to key working it back and forth into the lock.
Replace the batteries in both units. With mine, when the inside unit starts to deplete, it won't connect. The transmitter is a foot away from the display unit.
Measuring Tools... | Answered on Aug 10, 2020
You can try the following: 1# Check the main power cable & make sure it has 110V (Do not run the machine with long extension cable).2# Check all harness connection.3# Check keyboard cable connection on back of control board.4# If all the cable connection is good then you may need to replace the control board.
Measuring Tools... | Answered on Aug 02, 2020
Those are precision devices and require factory check up and calibration at regular intervals. Contact your dealer.
Measuring Tools... | Answered on Aug 01, 2020
Contact Acurite directly to inquire.
Measuring Tools... | Answered on Jul 04, 2020
Kwikset Brz Sgl Cyl Deadbolt Logo
15 questions posted
Top Kwikset Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Kwikset Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Kwikset Measuring Tools & Sensors
Most Popular Question
installing deadbolt in steel door need
  • Measuring Tools & Sensors
