20 Most Recent Casio Watch Sea Pathfinder Spf-60-1aver Unisex Gray Questions & Answers
I have replace the batteries and after assembled the mode and adjust buttons are not functional.
I've had the same problem with another Casio watch and in my case I didn't place the inner parts of the watch exactly right. This must be done very precisely, otherwise one or more button functions don't work. Maybe it is worth a try to check the alignment of the inner parts of the watch.
3/24/2015 2:52:49 PM • Casio Watch Sea... • Answered on Mar 24, 2015
I have a Casio Pathfinder 2805. The glass display screen is dirty on the inside. How do I remove the display screen to clean the inside?
Question edited for clarity. Question moved from Casio Business Machines. It is a job best left to a local jeweler when it is battery change time. The fact is got dirty inside means there must be damaged gaskets. If you want to do it yourself, remove the back and lift the movement out, being careful to not damage the button contacts. https://www.google.com/search?q=Casio+pathfinder+2805+remove+movement ..
4/9/2022 11:42:29 PM • Casio Pathfinder... • Answered on Apr 09, 2022
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
3/24/2015 3:42:40 PM • Casio Pathfinder... • Answered on Mar 24, 2015
How do set Casio model 6054 gw1000b
On the Casio website, this model 6054 isn't recognised. With the module number (you'll find it in a small rectangle on the back of the watch case) you can download the manual for your watch here: Timepieces Watches Manuals CASIO
3/24/2015 3:16:01 PM • Casio Pathfinder... • Answered on Mar 24, 2015
0answers
0answers
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
12/25/2013 3:12:33 AM • Casio Pathfinder... • Answered on Dec 25, 2013
Change time
What model Casio watch?
11/12/2013 12:32:30 AM • Casio Pathfinder... • Answered on Nov 12, 2013
0answers
My Casio digital watch changes the date at 12 noon rather than at midnight. The model is 5479. How can I solve this issue?
Time is not set correctly. You set the time as AM instead of PM and vice versa. Use the following manual to set time correctly. QW-5479 (casio.com)
12/31/2023 10:43:33 AM • Casio Watches • Answered on Dec 31, 2023
Why does everything equal zero when hitting EXE on
You may find a solution here:
http://world.casio.com/wat/download/en/manual/
If it does not work, use casioworld button on same page as it may help.
Rate me, please.
12/20/2023 1:53:16 PM • Casio Watches • Answered on Dec 20, 2023
Casio Watch Sea Pathfinder Spf-60-1aver Unisex Gray Logo
2 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Pathfinder Casio
  • Pathfinder Casio
Most Popular Question
replace batteries after assembled mode
  • Watches
