20 Most Recent Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Questions & Answers
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Schlage B362 605... | Answered on Nov 21, 2014
Try putting a thin oil on your key before you try to turn the lock . Also get a can of dry lube for locks & spray it into the lock
Schlage B362 605... | Answered on Jan 28, 2013
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Schlage B362 605... | Answered on Sep 22, 2012
Here is a link to the manual for rekeying all Schlade/Gatehouse locks.(It's in PDF format)You can download,save,print,or view online.
Please take time to rate this fixya
Schlage B362 605... | Answered on Aug 27, 2012
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Schlage B362 605... | Answered on Jun 20, 2011
a small set screw on inside knob. need an allen wrench
Schlage B362 605... | Answered on May 24, 2011
the inside has a push on plate to cover the screws, a little difficult to get off
Hello My name is Lori and I work at Schlage Customer Service. If this is not a Schlage Key it may be possible that they did not cut the key to the correct code. Look on your key for the 5-digit key code and make sure the keys align up exactly - the keys also should be the same width. Also when you install this B362 you should install it with the katch extended and the keys out of the cylinder. Try some of these tips and if you still need help - please feel free to call us at Schlage Customer Service: 1-888-805-9837 Good Luck!
Schlage B362 605... | Answered on May 13, 2011
Remove, lubricate with a dry silicone or graphite lubricant and reinstall. The mounting bolts may have loosened up, and now it is not perfectly lined up. More likely is some corrossion or wear in the throw mechanism.
Schlage B362 605... | Answered on Oct 13, 2010
my guess is that during installation the inside lock cylinders were 1/2 or a full rotation more in one direction than the outside cylinders. remove it from the door, assemble it and try it without installing it. If it doesn;'t work, take it back. If it's old, oil it. if that doesn't work- toss it- you've spent an hour on a $15 item.
Hello. get a can of a penetrating lubricant called WD-40. Squirt a little into both key holes and let it sit for a couple of hours. Then insert the key and work it back and forth. If it is still frozen, repeat the treatment until you break it free. Joe
Schlage B362 605... | Answered on Oct 09, 2010
I have been told the plate on the inside cylinder (where the key goes) comes off. Gently pry it off. Under that is the screws.
Schlage B362 605... | Answered on Oct 03, 2010
Ok. So what is the problem? The reinstall should be straight forward.
I'm Mike BTW
Schlage B362 605... | Answered on Sep 07, 2010
The best thing you can do is shave down a pencil(the lead)The lead shavings act as a lubricant,make a small pile of shavings and blow it into the key hole.Do not use a liquid lubricant,it'll gum up the lock,other then that you could try backing off the two screws holding the lock to the door,don't go so far as to have the lock move.hope I've helped...Don't for get to rate.....
Schlage B362 605... | Answered on Jun 13, 2010
Hasn't anyone solved this in over a year? I have the same problem. Can't Schlage provide service info on their products?
Schlage B362 605... | Answered on May 07, 2010
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
41 questions posted
Top Schlage Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Schlage Measuring Tools & Sensors
Most Popular Question
two month
  • Measuring Tools & Sensors
