20 Most Recent Schlage B362 619 KA4 Dbl Cyl Deadbolt Per 004 Ea Questions & Answers
there are 2 buttons on 1 on either side of inside key slot.. those must be removed... more than likely you will destroy them when removing..under you will find square drive screws or phillips..https://www.schlage.com/en/home/products/B62FFF.html
Schlage B362 619... | Answered on Oct 24, 2017
This sounds like the fit between the thumbturn and the bolt is compromised. If you pull out the thumbturn, take a look at the flat metal blade that fits into the rectangular or "8" shaped hole in the deadbolt mechanism. I think this has become bent or misshapped somehow. Or maybe the hole has a rough burr on it. You might be able to flatten the blade with a hammer and anvil or maybe dress up the problem with a file. Good luck.
Schlage B362 619... | Answered on Dec 04, 2012
You didn't indicate what mode. The little pins you refer to should be little caps snapped into the end of the screws. A very small screwdriver or a pocket knife should be able to remove them. Then you should have a screw head to work with. I can't remember, but it might be a square bit not a phillips head. See web site and look at installation instructions.
http://consumer.schlage.com/products/Productdetail.asp?StyleID=34
Schlage B362 619... | Answered on Aug 27, 2012
There should be caps over two screws above and to both sides on the interior key cylinder. Carefully use a pointed tool to pry them out. This will expose the phillips head screws that hold the two halves of the lock together.
Schlage B362 619... | Answered on Sep 24, 2010
This must be cut and drilled out unless you gret a locksmith to pick the lock open by manipulation
Schlage B362 619... | Answered on May 31, 2010
I have a schlage dead bolt lock and the key is difficult to get out
Schlage B362 619... | Answered on Jan 29, 2010
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Schlage B362 619... | Answered on Jul 22, 2009
The bolt may be bound against the side of the frame plate. If both sides are off the deadbolt, use a flat blade screw driver to turn the lock to the unlocked position while turning the knob and jiggling the door. If the key simply does not turn, the cap nut around the cylinder needs to be tightened. It should be tightened all the way, then loosened until the pin is in the first notch back.
Schlage B362 619... | Answered on Jul 17, 2009
Try pulling and pushing on the door a lot as you turn the key, there may be stress on the door and deadbolt causing it to not quite unlock all the way.
Schlage... | Answered on Apr 14, 2014
5505E MEASUREMETER BATTERY CHANGE (3V CR-2032)
REMOVE WHEEL AND SHAFT BY GENTLY PULLING AXLE OUT OF UNIT.
DRILL OUT 7 PLASTIC HEADS WITH 3/16 DRILL BIT. (ABOUT 1\8 DEPTH)
SPLIT TWO SIDES OF CASE AND REMOVE HANDLE.
SLIDE OUT CLEAR PLASTIC CONTROL UNIT. PUSH DOWN ON BUTTONS AS YOU REMOVE SO AS NOT TO DAMAGE THEM.
PUSH DOWN SLIGHTLY TOWARD THE CASE ON LOCK TABS WHILE GENTLY PULLING CASE APART. START ON ONE END AND WORK YOUR WAY TO OTHER END. KEEP GASKET INTACT. OPEN CASE.
THERE IS A "Y" SHAPED RETAINER HOLDING IN THE BATTERY. WITH NEEDLE NOSE PLIERS, CAREFULLY SLIGHTLY SQUEEZE THE BOTTOM OF THE "Y" AND PULL UP GENTLY. YOU CAN NOW REMOVE THE BATTERY AND INSTALL THE NEW ONE. PUSH RETAINER DOWN TO LOCK BACK IN.
MAKE SURE GASKET IS IN PLACE AND PUT CASE BACK TOGETHER, MAKING SURE WHEEL ADAPTER IS IN PROPER PLACE. TURN ON AND TEST CONTROL UNIT AND TURN WHEEL ADAPTER TO MAKE SURE UNIT IS WORKING PROPERLY.
SLIDE CONTROL UNIT BACK IN BEING CAREFUL OF THE BUTTONS. RE-ASSEMBLE HANDLE AND PUT THE TWO SIDES OF THE CASE TOGETHER. I USED THREE PIECES OF ELECTRICAL TAPE TO HOLD CASE TOGETHER. ONE ON THE TOP BETWEEN THE TWO HOLES, ONE ON THE BOTTOM JUST ABOVE THE DISPLAY, AND ONE IN THE MIDDLE.
PUT THE PLASTIC PIECE IN THE HOLE AND LINE UP. MAKE SURE BOTH O-RINGS ARE ON THE AXLE SHAFT. GENTLY INSERT AXLE ALL THE WAY IN WHILE ROTATING IF NECESSARY.
I WAS SO HAPPY I HAD IT ALL BACK TOGETHER AND WORKING, I HADN'T TAKEN ANY PICTURES AND I DIDN'T FEEL LIKE TAKING IT ALL APART AGAIN. MIGHT ADD PICTURES LATER IF NEEDED. I HAD BEEN LOOKING FOR YEARS ON HOW TO CHANGE THE BATTERY, AND I FINALLY MADE UP MY MIND THAT I WAS GOING TO DO IT.
JMS 10-20-2020
Measuring Tools... | Answered 2 days ago
You can try the following: 1# Check the main power cable & make sure it has 110V (Do not run the machine with long extension cable).2# Check all harness connection.3# Check keyboard cable connection on back of control board.4# If all the cable connection is good then you may need to replace the control board.
Measuring Tools... | Answered on Aug 02, 2020
Those are precision devices and require factory check up and calibration at regular intervals. Contact your dealer.
Measuring Tools... | Answered on Aug 01, 2020
Schlage B362 619 KA4 Dbl Cyl Deadbolt Per 004 Ea Logo
Popular Tags
17 questions posted
Top Schlage Measuring Tools & Sensors Experts
Michael Thomas
Michael Thomas
Mike
Tom Weglarz
Tom Weglarz
Level 1 Expert
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Schlage Measuring Tools & Sensors
Most Popular Question
deadbolt lock closet key no longer
  • Measuring Tools & Sensors
