20 Most Recent Black & Decker BDL400S Bullseye Crosshair 90 Degree Auto Leveling Interior Line Laser Questions & Answers
There is a micro-fine, almost
The two very fine red wires connect here. black & decker-kd0ysdieigozt2ge0gqdsflt-3-0.jpg
4/16/2017 6:27:14 AM • Black & Decker... • Answered on Apr 16, 2017
Black and decker crosshair laser level
The really fine wire is soldered from the RED terminal on left to the RED terminal on the top left (underneath the board). See below in the images. black-decker-crosshair-laser-level-2bsxhpa3po2xrabjzw4jy444-1-0.jpg black-decker-crosshair-laser-level-2bsxhpa3po2xrabjzw4jy444-1-2.jpg
3/30/2015 2:16:08 AM • Black & Decker... • Answered on Mar 30, 2015
The laser light on my black & decker bdl500 stopped working
I had the same problem with mine. I took it apart and inspected it. Mine was a loose connection and after some fiddling with the wires the laser came back on. Put it back together and haven't had a problem with it since. Hope it helps.
3/30/2015 1:40:56 AM • Black & Decker... • Answered on Mar 30, 2015
0answers
How do i calibrate a black & decker BDL220S laser level
Rotate the laser to center horizontal (H) or vertical (G) bubble vials
9/11/2022 3:59:12 PM • Black & Decker... • Answered on Sep 11, 2022
2answers
I have a BDS 300 sensor and have lost instructions
I just bought one too and instructions need deciphering. Select wood or metal with selector switch. Put unit flat against wall. Press and hold on/off button on left. (It looks like it must be kept pressed in at all times to be 'on' and when released it's 'off). The unit with calibrate and give a beep back and lower red LED will stay on. Move unit slowly left/right and more red LEDs light up until green is on. This is 1st edge. Mark it with pencil. Move unit along until Green is off and down to single LED. Then move it back in opp. direction until Green is on again. This is 2nd edge. Attached is a scan of page from Instruction Manual. Quality is lowish as attachment limit here is 150kb.e4edea4.jpg
1/29/2013 10:11:15 PM • Black & Decker... • Answered on Jan 29, 2013
I have no laser light when I turn my level on
Check to make sure battery isn't bad first.. If upon changing the battery, it still doesn't work, the laser might be bad or worn out. Good luck... HDTV GURU JAY
3/16/2011 1:51:44 PM • Black & Decker... • Answered on Mar 16, 2011
CHarging light blinking while trying to charge
Battery is old...time for a new one.
9/3/2009 5:12:36 PM • Black & Decker... • Answered on Sep 03, 2009
2answers
What do Indoor air quality meters measure?
They measure the humidity, CO2 levels, CO levels, temperature and also the dew point, wet bulb as well as the outside air.
11/30/2022 4:57:13 AM • Measuring Tools... • Answered 5 hours ago
Black & Decker BDL400S Bullseye Crosshair 90 Degree Auto Leveling Interior Line Laser Logo
Popular Tags
9 questions posted
Top Black & Decker Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Measuring Tools & Sensors
Most Popular Question
micro fine almost
  • Measuring Tools & Sensors
