20 Most Recent DeLonghi BAR 140 Espresso Machine Questions & Answers
Frother failure
DeLonghi BAR 140... | Answered on Dec 04, 2017
get in an electrician that you believe to trade qualified and have him check the wiring insulation and installation
the RCD tripping can be a very small imbalance in the circuit , dead short or overload and not necessarily in the unit
it could be in a problem wire in the power lead
DeLonghi BAR 140... | Answered on Nov 15, 2017
if it has warranty return it back the machine is faulty.good luck
DeLonghi BAR 140... | Answered on Sep 25, 2011
I like my coffee pretty strong and I use 2/3 cup coffee to 10 cups of water...
You may be able to use 1/2 cup to 10 cups if you don't want it too strong...
You must experiment a bit as different coffees will vary also...
heatman101
DeLonghi BAR 140... | Answered on Apr 30, 2011
If this is a new unit, you should return it. If you don't have that option, you'll have to open it up and tighten some screws that hold the wires into their respective barrier strips. Delonghi often doesn't tighten them quite enough. The unit will sort of work. The problem may be finding all the screws to remove to get in and that some of them are 'tamper' style. It is also possible that the temp sensors are not fitted right or are defective. Good luck.
DeLonghi BAR 140... | Answered on Oct 26, 2008
Obviously, this unit has a warranty. Are you packing the coffee too tightly? Run the unit without any coffee and see if the vibration is still there. If it is, get it fixed. If not, modify what you're doing.
DeLonghi BAR 140... | Answered on Feb 23, 2008
You probably are overfilling the steam reservoir. If the unit is showing that it has reached temperature, that is your likely problem.
check the filter holes. They might need to be cleaned with a needle.
DeLonghi BAR 140... | Answered on Jan 27, 2008
I beleive these are the instructions you were looking for. http://www.delonghi.co.uk/pdf_files/BAR14.pdf
If not the correct model, please post back and I'll do my best to help you further. I hope this helps.
DeLonghi BAR 140... | Answered on Nov 29, 2007
the filter has a little indent that must be placed correctly, if you put the filter in the holder and then rotate the filter you will feel it click into place when it is in the right position ( there is a gap for the indent at the front of the holder)
DeLonghi BAR 140... | Answered on Nov 02, 2007
EVER TURN IT OVER AND LOOK FOR THE LEAK . USUALLY CAN NOT BE FIXED JUST REPLACED
DeLonghi Coffee... | Answered 10 hours ago
THESE ARE NOT CONSUMER REPAIRABLE THROW IT IN THE BIN AND GET A BETTER GRADE OF MACHINE
DeLonghi Coffee... | Answered on Sep 14, 2020
CONTACT TECH SUPPORT FOR DELONGHI WE ARE NOT THEM
DeLonghi Coffee... | Answered on Jul 23, 2020
DeLonghi BAR 140 Espresso Machine Logo
25 questions posted
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
DeLonghi Coffee Makers & Espresso...
  • DeLonghi Coffee Makers & Espresso...
Most Popular Question
much coffee add
  • Coffee Makers & Espresso Machines
