20 Most Recent Proform 380 CS Treadmill ! Questions & Answers
Check to see that the treadmill does not draw more amp than stated in the owners manual. If you are, then the problem is in treadmill. If not try another circuit in the house (not just another receptacle).
Proform 380 CS... | Answered on Oct 01, 2014
1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
Proform 380 CS... | Answered on Sep 21, 2012
see the video and use the common sense.
God bless you
Proform 380 CS... | Answered on Sep 18, 2012
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_14_2011_4_33_45_pm.gif11_14_2011_4_34_07_pm.gif
Proform 380 CS... | Answered on Nov 14, 2011
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
Watch this video.
1) observe if the main motor is running, be carefull with you hands.
2) See the drive belt motor is o.k or is broken and replace+ or flywheel is loosen or broken too.
3) Test if the motor is turning with good speed adjust speed. Test the speed sensor.
http://www.youtube.com/watch?v=23ZgWaVEQjA
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Some equipment has two sections in the board SCR:
Led up +dn. up= up WHEN THE MOTOR UP AND VICE-VERSA.
after that has 2 relais test for open and closes. clean the contact with special spray for clean contact. If the problem persist, the motor or the board is faulty.
Proform 380 CS Treadmill ! Logo
44 questions posted
Top Proform Exercise & Fitness Experts
Marvin
Marvin
john h
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
cannot turn proform 380 cs treadmill
  • Exercise & Fitness
