20 Most Recent RTO Bodyguard T200 Treadmill Questions & Answers
I need a replacement board "microcomputer" for a Magellan Bodyguard Treadmill??
please go to www.fitnessrepairparts.com and buy iy otwww.doctortreadmill.comHappy New Year. God bless you
1/1/2013 11:02:29 PM • RTO Bodyguard... • Answered on Jan 01, 2013
Elevation Will NOT go down after the elevation calibration
Unplug unit and remove motor shroud if you are savvy with a multi meter then try these trouble shooting procedure:
Perform and elevation calibration again, On the display, can you see numbers counting down and up and the treadmill is going up and down? If yes then the unit will proceed to work, if no when power is on, check on the lower board, on connector J5, do we have 5V DC between pin 1 & 3? If yes During Calibration, J5, between Pin 5 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 4 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 2 & 3, on the lower board, do we have DC voltage varying from 1.15 to 3.00? If any of the above is no then then the lower board will need replacing if all is yes then elevation motor needs replacing.
8/1/2010 12:32:55 AM • RTO Bodyguard... • Answered on Aug 01, 2010
Pro-form treadmill belt binds
May need to be tightened www.AtlantaFitnessRepair.com
8/24/2009 6:26:54 PM • RTO Bodyguard... • Answered on Aug 24, 2009
Weight limit not exceeding 136
It sounds like it is set to read kilograms instead of pounds,check your manual to set the treadmill to english instead of metric
8/1/2009 3:07:47 AM • RTO Bodyguard... • Answered on Aug 01, 2009
Belt shifting/crooked and frayed on Proform 725 TL
in the back of the manual, it describes the adjustment for this. on the end of the platform (near where your belt is crooked) there is a hex nut. the manual says to turn the machine off before adjusting, i find it is much easier to do while the tread is still moving. turn it about a quarter or half turn one way or the other until the tread is aligned.
6/29/2009 10:00:05 PM • RTO Bodyguard... • Answered on Jun 29, 2009
Treadbelt not alligned
Hi, Most all treadmills use the same type of belt tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
3/4/2009 1:52:30 AM • RTO Bodyguard... • Answered on Mar 04, 2009
2answers
We just bought a gently
From the manual: Troubleshooting Symptom: The walking belt slows when walked on a. If an extension cord is needed, use only a 14-gauge general purpose cord of five feet or less in length. b. If the walking belt is over-tightened, the treadmill performance may decrease and the walking belt may be permanently damaged. Remove the safety key and UNPLUG the power cord. Using the 3/16" allen wrench, turn both rear roller adjustment bolts counterclockwise. 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each side of the walking belt 3-4 inches off the walking platform. The center of the walking belt should just touch the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert safety key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. c. If problem persists, contact customer service.
9/18/2017 9:33:09 PM • RTO Exercise &... • Answered on Sep 18, 2017
Trotter 3300 climber parts schematics
Repair Parts for Trotter 3300 Climber SPORTSMITH net You can find some of the required information at the link above.
9/29/2015 6:35:08 PM • RTO Exercise &... • Answered on Sep 29, 2015
0answers
0answers
0answers
0answers
RTO Bodyguard T200 Treadmill Logo
Popular Tags
13 questions posted
Top RTO Exercise & Fitness Experts
Jennifer Rock
Jennifer Rock
Aron
Sportsmith LLC
Sportsmith LLC
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • RTO Exercise & Fitness
Most Popular Question
need replacement board microcomputer
  • Exercise & Fitness
